Leveling out a T100 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-22-2009, 11:43 PM   #1 (permalink)
Leveling out a T100
I just bought a 97’ T100 3.4 4x4 manual trans. and have a lot of modifications planned for it. It is going to be my second project replacing my first project a 94’ V8 4x4 Dodge Dakota converted into a Baja surfing camping machine (you can check it out on CL @ http://ventura.craigslist.org/cto/1227306416.html). I decided to go Toyota for the reliability factor because I plan on keeping this one forever. I am on this site all the time getting ideas and it has been really helpful.
So here’s my questions:
- I want to put BFGs 32x11.5 on 15” black rims, which from my research should be no problem. Not sure what the backspacing should be, I was thinking about 3.75 ??? , I would like them to stick out a little bit, maybe an inch from the fender, but not too much. Does anyone know about what backspacing I am looking for???
-My big issue is the stance of the T100, the rear end sits up higher then the front, I don’t like it. I would like it to sit just a bit higher in the front. I don’t want to crank the torsions, I thought about BJ spacers, but I figure I don’t plan on doing any rock crawling and it seems to me like the clearance is enough for the trails that I drive so I was wondering if it is possible to lower the back end a little like 1.5”. I am planning on putting a camper on the back and decking it out for camping like the Dakota. So I don’t want the back end as high as it is right now, too hard to get in and out of the camper. So is this possible, and how do I do it ???? I searched for different spring shackles, no luck. I figure maybe new leaf springs?? Will I have any problem running 32x11.5s?? I also thought maybe a combo of lowering the back 1” and raising the front with BJ Spacers.
G100 is offline
Old 06-23-2009, 12:12 AM   #2 (permalink)
CRafferty's Avatar
A1: The backspacing should be 3.75 to 4" (I think)
A2: I think that BJ spacers should do the job pretty well, though I'm not sure how intense your rake is on the rear.
__________________
Lilly:
1992 4Runner 4x4 SR5
3.0L V6 32" BFGoodrich A-T T/As Pro Comp ES3000s
4Crawler BJ Spacers and Coil Spacers. ISR Mod.
Soon: 4.88's, LC's, Skids.
Her page: http://www.yotatech.com/f78/collin-s.../#post51096834
Ike:
1947 Willy's Jeep
Ford 134L I4
1ton 3" lift springs on 33x6.5 Mud Terrains
Quote:
Originally Posted by Matt16 View Post
Toyota makes the Hilux. Complementary base-pairing makes a (double) helix.
Quote:
Originally Posted by Jimmeh View Post
As long as people listen to music, then at least they are human, right?
CRafferty is offline
Old 06-23-2009, 12:40 AM   #3 (permalink)
scuba's Avatar
Sounds like its got an AAL..
Check that rear packs and see if it has something that looks like an add a leaf..
__________________
Screw you guys I'm goin to TTORA
Mods, please be mature and leave my sig alone, thanks.
No, I will not be your friend.
scuba is offline
Old 06-26-2009, 09:37 PM   #4 (permalink)
it doesn't look like its got an add a leaf to me, three springs two full length and one half. Has anyone seen after market shackles that will lower it a bit?
G100 is offline
Old 06-26-2009, 10:09 PM   #5 (permalink)
Kiroshu's Avatar
possilbe new and or different shocks in rear... usually the frontend of toyotas never wear out, mostly the back....
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
(Still working on restoring her)
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
(sold)______________
(Was my fastest truck i miss her...)
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
(was my quietest and slowest yota.)
Kiroshu is offline
Old 07-07-2009, 09:30 PM   #6 (permalink)
Torsion bars
Try changing the Torsion bars. I changed to some Downey 26mm. here is what they state on their web sit "The stock 4WD front torsion bars are 22.8mm, which is adequate for stock 28” tires and wheels, or for normal highway use with heavier tires and wheels. Install a set of 31” tires (or larger) then go off road with your 22.8mm torsion bars and see what happens. The heavier the tire, the worse your off road experience will be". I'm looking to use the add a leaf to level my T100. The front end is now about 1.5" or more is taller than the rear end.
http://www.downeyoff-road.com/Suspen...-98_T-100.html
Good luck
jimmck is offline
Old 07-07-2009, 09:56 PM   #7 (permalink)
toyota4x4907's Avatar
Send a message via MSN to toyota4x4907
The rear is higher because its a truck...and you load the bed with stuff...usually heavy stuff...then when its loaded, it won't look like a granny butt.
IF you're going to do a camper and all that jazz, I would suggest leaving the rear alone so the weight of everything in the rear will level it out, not make it sag.
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 | CompuStar Auto-start| two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler
'88 4runner|22re|5spd|206K miles|Sold
'93 single cab|22re|5spd|150K miles|Sold|
Pro IFS
toyota4x4907 is offline
Old 07-08-2009, 10:42 PM   #8 (permalink)
Hey Jimmck, hows the ride? are you bouncing around like a bobble-head? I feel like I wouldn't want any stiffer then what I got right now. I talked to guy from ORW and he told me to stay away from Ball Joint Spacers because the break, first I have heard of that, does anyone know anything about problems with BJ spacers.
__________________
97' T100 Xtra-cab SR5 4x4 Manual trans.
G100 is offline
Old 07-15-2009, 12:26 PM   #9 (permalink)
Rides good
I thought i posted a reply last week but.
The truck rides a little stiffer but of road it handles a lot better. i replace all the rubber on the sway bar with poly and cleaned things up real good and after looking every thing over i have come to the conclusion that a total SAS is the best way to go with this truck. the ball joint spacers are a bit scary to me. you have to cut a big chunk out of the upper control arm and i have heard of them breaking after doing this. If you are looking to keep the smooth ride that the T100 is known for you might find this web site interesting.
http://home.4x4wire.com/erik/t100/
He did a really nice job on his but it seams that with the amount of welding he did i would rather go with the SAS.
Good luck.
jimmck is offline
Tags
100, 30, add, backspacing, camper, forum, leaf, t100, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
