Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
how to separate rotor/hub on 96 4wd?
I can't figure this out..shop manual simply says remove disc(rotor) from hub.
Can't figure it out, neither can any of the parts store guys. My truck is apart and waiting for the new rotors! Any help would be greatly appreciated! |
| Sponsored Links |
#2 (permalink) |
take the caliper off, soke everything but the rotor in PB,take a rubber mallet, and beat the ลลลล out of it
__________________
2003 4WD TRD Tacoma 1986 4Runner |
#3 (permalink) |
The PB has been soaking in for a couple of hours and I'll try again in the morning....still don't see how the hub is going to pass through the center of the rotor, though.
#4 (permalink) |
have you tried with a rubber mallet?
i had to get mid-evil on my taco when i got the rotors turned. where are you at? pics help alot
__________________
2003 4WD TRD Tacoma 1986 4Runner Last edited by jjrgr21 : 12-03-2006 at 08:36 PM. |
#5 (permalink) |
take the caliper off, ziptie it to the A-Arm.
grab a rubber mallet and go to town. Hit closest to the edges as possible. |
#6 (permalink) |
Both rotor/hubs are removed and have the six bolts holding the rotors to the hubs removed. This picture is one of them soaking in PB. Last edited by rockmaker : 12-04-2006 at 12:19 AM. |
#7 (permalink) |
you should be able to turn it over and put the lugs back on and hammer them and it will loosen up.. that how i've done it before.
__________________
3genRunner: including parts from 3 generations of 4runners, '92 pickup, '80something Land Cruiser, Chevy truck, Ford sedan 89 4runner: Project DD. 3.0, needs a new tranny 81 2wd pickup: 22R | 5-sp | long bed | quad hauler, leaks oil but gets 26mpg 91 Honda Prelude: the Daily Driver WA, OR or CA wheeler?? Check out pacific-crawlers.com and check out yotaworks.com |
#8 (permalink) |
Are you sure it's a 96, that hub/rotor is from a 2nd gen Runner, ie 89-95. If I remember correctly the rotor comes off from the back, so the hub doesn't have to go through the rotor. Anyway they are usually stuck together pretty good, try finding the crack between them and hammering a sharp chisel in, go round and do that in a few places. You can also try putting the rotor on blocks and hammer out the hub. Use a piece of wood so you don't damage the hub.
#9 (permalink) | |
Quote:
__________________
Steve Schaefer WWW.SonoranSteel.Com Suspension Lift Kits * Rock Sliders * Straight Axle Conversions * 4Runner/FJC Rubicon Express Lower Links * Accessories * Daystar Products Dealer * TJM Bull Bar Dealer * Deaver Leaf Spring Dealer * Tokico & Bilstein Shock Dealer * ViAir Dealer * Total Chaos Dealer * and like everyone else a Trail Gear Dealer |
#10 (permalink) |
As far as I know these are the original hubs, but I bought my truck used. It is definitely a 1996, though. The hub has to pass through the rotor for it to come apart. The holes visible in the pic are where the rotor/hub attaching bolts go. The rotor is not threaded, the part of the hub behind the rotor is. Interestingly enough,though, the FSM does not show these bolts or even the fact that the rotor and hub come apart!
#11 (permalink) |
center the rotor on 2 peices of wood or non course surface, and use a 2x4 to wack the center of hub, works every time, at least for me it does.
__________________
98 4Runner Limited |
#12 (permalink) |
The FSM picture you posted is for an 86-95 truck. Not an 96.
Go here and look at some 96 FSM pages. http://www.sonoransteel.com/junk_yard_manual_hubs.html THIS is a 96-04 Tacoma. http://www.sonoransteel.com/Aisin_Tacoma_Hubs/SA-31.pdf
__________________
#13 (permalink) |
Well, my shop manual is straight from Toyota for a 1996 T100. I talked to the parts guy and he said there are 3 different rotors depending on my VIN. I am going to talk to the service department now to see what they say.
#14 (permalink) |
Well you never said it was a T-100, yes those had the old stuff for many more years.
Your book is right, for a T-100 but not for a Tacoma.
__________________
#15 (permalink) |
After a $&!t load of pounding, they came apart! Tempe Toyota service guy recommended this method too. Thanks to all for the help! Now to get everything back together....
#16 (permalink) |
#17 (permalink) |
I did not even know there was a T100 section. I found this under "new posts".
Now I know there is a T100 section.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Removing rotor/hub | SpeedyManiac | 86-95 Trucks & 4Runners | 36 | 06-12-2007 06:13 PM |
| manual hub-rotor question | E-money | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-26-2007 04:03 PM |
| separating front rotor from axle hub. | timmie | 86-95 Trucks & 4Runners | 5 | 08-07-2006 02:02 PM |
| can't seperate rotor from hub | Brendan | 86-95 Trucks & 4Runners | 27 | 03-31-2006 09:05 AM |
| Rotor/hub | tpg013 | Maintenance & Repair Archives | 10 | 02-18-2003 05:04 PM |
