93-98 T100s All T100 trucks
Help with oil housing gasket
Old 02-13-2011, 08:23 PM
arielb1's Avatar
Hey guys,
Im trying to earn some karma here. My neighbor has a 1996 T100 4 banger. It is leaking oil heavily. From underneath, I can see the drippings coming out of the passenger side motor mount. Above the motor mount, it appears to be the oil filter housing that connects to the engine block. There are two bolts that hold the housing to the engine block
Question, is there a gasket that can be broken on ripped between the housing and engine block?
If I remove the two bolts from the housing to the block, will I destroy or disconnect anything?
What can be between the oil filter housing and engine block? What is it called? Im assuming a gasket of some sort.
When I replace the gasket, do I use FIPS some gasket sealer?
Anyone have a diagram I can reference?
Many thanks..your advise is greatly appreciated...good karma to you.
Old 02-14-2011, 12:42 AM
BamZipPow's Avatar
Wink
Does that answer yer questions?
Using www.toyotapartsales.com this is what the part number referenced to...
Item Number MSRP Core Price Price
1569275011 $4.20 $0.00 $3.04
GASKET, OIL FILTER B
Old 02-14-2011, 06:51 AM
arielb1's Avatar
Thank you BamZipPow,
This is exactly what I am looking for.
Ive got part number...thank you. Looks like I have to order from my local toyo dealer since there is an order limit of $10.
When I go to ToyoDIY.com, I can see the parts list. It looks like toyodiy removed the diagram. Anyone know of another site where they have diagrams for my future reference? I've searched but striking out.
Many thank you and karma. I'm very grateful to you.
Ariel
Old 02-14-2011, 07:26 AM
BamZipPow's Avatar
There isn't really another place...
BTW...you have PM!
the1998sr5
15
07-14-2020 08:35 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Help with oil housing gasket
