YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-15-2007, 01:10 PM   #1 (permalink)
gas mileage
everywhere i look peoples t100s are gettin 18-20mpg but mine only gets 15-17 and that is driving conservativley. mine is completely stock 97 sr5 with 153,xxx miles. if someone can piont me in the right direction on how to make it better i would greatly appreciate it
__________________
97 t100 sr5 currently stock but not for long. future plans-2'' body lift, 33x12.50 tires, 2'' lift shackles, 1.5'' ball joint spacers, and a trd supercharger
fezzyt100 is offline
Sponsored Links
To remove this ad, register today!
Old 08-15-2007, 01:47 PM   #2 (permalink)
ewong's Avatar
auto or stick?
4cly or v6?
How far off are you from the EPA numbers?
http://www.fueleconomy.gov/
ewong is offline
Old 08-16-2007, 07:20 AM   #3 (permalink)
3.4 v6 auto
__________________
Old 08-16-2007, 08:06 AM   #4 (permalink)
ewong's Avatar
EPA Adjusted "new"standard" - 14mpg city 16mpg highway.
Yer right on target
Note that the MANUAL is 15mpg city - 17mpg highway
a 96 2WD 4cly manal is 18/22 and a 2WD 4cly auto is 17/20
So there's the differnce
Ditcht he transfer casem the front axle (probably what - 500lbs) and get a manual... and violia
Or get a Honda Civi
ewong is offline
Old 08-16-2007, 10:36 AM   #5 (permalink)
good to know. thanks a lot
__________________
Old 08-16-2007, 10:41 AM   #6 (permalink)
CJM
CJM's Avatar
Bout what I get, 16mpg city if I am lucky. I have a 96 3.4L Auto with 31's but they ride rough (tires). best I have gotten was 17-18mpg or so during october.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 08-16-2007, 10:52 AM   #7 (permalink)
ewong's Avatar
Beating the EPA numbers is doable but
-- not easy
-- not inexpensive
-- usually not feasible for a DD
Some of the things are "banned" by the EPA - as int he manufs cant used them to improve fuel economy on the Govt test - but you can use them
-- synth lube
-- lower rolling resistance tires (increased air pressure etc)
Others are do-able but often not feasible
-- TALLER gears
-- cut out weight
ALot of it has to do with the driver's right foot and is often not realistic on a road with other cars.
Long run - Id toss out a max of 20% improvement on the high side - so that means a 20mpg goes to 24mpg?
But a realistic number is a 10% improvement - and even that takes discipline - so thats 20mpg boosted to 22mpg.
In your case that means a 15mpg becomes 16.5mpg and a high (but probably unrealstic 18mpg) and note that even that 18mpg is still in the EPA "window" at the highway level...
TANSTAAFL
ewong is offline
Old 09-01-2007, 08:40 PM   #8 (permalink)
i just bought a 95 t100 4x4 ext cab 3.4 with 5speed. this thing turns around 3000 rpm at 70 miles per hour whereas my fiances 4runner with the auto turns barely 2200 rpm at 70. i expected bad mileage with such a high cruise rpm but got 20 mpg country/town driving and 21.4 highway on a trip to indiana! im rather happy! i also drive like a grandpa and set the cruise at 65 ish on the highway. id like to know why the drastic difference in the cruising rpms between the 5 sp and auto trannies.
mywomanstaco is offline
Old 09-13-2007, 01:37 PM   #9 (permalink)
Quote:
Gonna guess that yer differential ratio is higher than her auto. You wouldn't happen to know what it is fer yer truck, do you?
BamZipPow is offline
Old 09-13-2007, 01:49 PM   #10 (permalink)
Bagger's Avatar
T100's - manuals come with 4.10's stock, auto's come with 4.30's stock.
__________________
'97 T100 ~ TRD SC ~ ARB ~ FWC
'85 FJ6O ~ 4E9 ~ locked ~ 33's
'87 Turbo 4Runner ~ sold
Bagger is offline
Old 10-28-2007, 06:32 PM   #11 (permalink)
DMG
Quote:
The m/t overdrive is about .85 whereas the autos is about .70:1
DMG is offline
Old 10-29-2007, 07:16 AM   #12 (permalink)
The best I ever got in my 93 2WD T100 auto was 26.4mpg highway/day/light load...and that was driving around 60 miles per hour. I average around 20-22 on the highway now traveling around 65 miles per hour at night. The lowest I got was around 14 miles per hour towing my car...
Old 10-29-2007, 06:35 PM   #13 (permalink)
Froggy93's Avatar
I wish I could get that kind of gas mileage with my T100. best I ever got was about 18.5. that was doing about 70-73 down the highway. but, I expect that with the factory gears. 4.70 stock. crank about 3000rpms at 68ish miles per hour.
__________________
93 T-100 3.0 5spd 4x4 high flow cat, custom duals
17" Powder coated Sequoia wheels
32" Mickey Thompson Baja ATZ tires stock lift
brand new factory rear axle housing, seals, brakes, everthing but origional axle shafts and third member.
new factory clutch- if you order from Downey, make sure you get the right one:(
diff breather mod.
Froggy93 is offline
Old 10-30-2007, 06:55 PM   #14 (permalink)
I had a 95 xtra cab sr5 4x4 5 speed..I was getting 17 around town and 20 on the hwy from the time I bought it till I sold it..I put 130,000 on it and sold it had 194,000 on it..Several times i got 21 mpg out of it..
__________________
04 Tacoma Double Cab 4x4 TRD..
RETRO is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Gas Mileage/gas brand Bamataco1 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 15 11-03-2005 01:47 PM
Gas mileage slyphr 95.5-2004 Tacomas & 96-2002 4Runners 3 03-07-2005 09:15 AM
Will My Gas Mileage Really Go Down??? carose725 95.5-2004 Tacomas & 96-2002 4Runners 6 01-11-2005 12:14 AM
Gas Mileage Again Rays94runner 95.5-2004 Tacomas & 96-2002 4Runners 20 04-14-2004 02:51 PM
My best gas mileage ever!!! AgRunner06 95.5-2004 Tacomas & 96-2002 4Runners 13 05-28-2003 12:35 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
