Front differential problems? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-14-2009, 07:22 PM   #1 (permalink)
Question Front differential problems?
i have got a 1996 toyota t100 and my front diff recently blew on it i am not sure what gear ratio i have in it i was wondering if anyone knows how i can tell what it is, if maybe the id tag has it or the ring and pinion all i think is the pinion has 10 and the ring has 41 i just bought the truck as a project and i need help on this?? anyone?
yotat100 is offline
Old 06-14-2009, 07:26 PM   #2 (permalink)
algranger's Avatar
On the older trucks the butt end of the pinion gear is color coded, you can see it from the outside with the driveshaft on. Check that (not sure if a newer t100 would have that) maybe call the dealership and see if they can help you I.D. it
Good luck
__________________
I said lie, for me
lying under a process tree
algranger is offline
Old 06-17-2009, 06:50 PM   #3 (permalink)
Froggy93's Avatar
if you 10 teeth on the pinon and 41 on the ring gear, then you have 4.10 gears.
__________________
93 T-100 3.0 5spd 4x4 high flow cat, custom duals
17" Powder coated Sequoia wheels
32" Mickey Thompson Baja ATZ tires stock lift
new factory clutch- if you order from Downey, make sure you get the right one:(
diff breather mod.
cobra cb
custom rear bumper w/tire carrier-Kennasaw Mtn. acc.
In the works. light bar and hella 500's
Froggy93 is offline
Old 06-19-2009, 09:41 AM   #4 (permalink)
From 4x4wire
AXLE- Gear ratios
Axle code found on door jamb
A10A = 4.10
A11A = 4.30
4.10's usually came in manual transmission 4x4 trucks, 4.30's in auto transmission 4x4 trucks.
__________________
96 White T100 4x4 Extracab, Lifted, locked, & 35s
Currently out of service due to roll over. Pending body work, SAS and rollcage
Kookadala is offline
Tags
differential, front, pinion, problems, repair, ring, sequoia, t100, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Rear axle/differential problems Onedeeare 84-85 Trucks & 4Runners 8 05-14-2009 06:28 PM
1994 4X4 Toyota Rear End Differential Problems JNetTrecker 86-95 Trucks & 4Runners 0 08-20-2007 06:25 PM
driving without the front differential Brendan 95.5-2004 Tacomas & 96-2002 4Runners 1 10-24-2005 11:08 AM
Differential problems 87T4R Maintenance & Repair Archives 4 05-08-2005 08:45 PM
Leaking front differential lzyellodog 95.5-2004 Tacomas & 96-2002 4Runners 0 03-17-2005 06:30 AM
2009 InternetBrands, Inc.
