| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Fan Blade breaking? Please Help!!!!
__________________
Pain is Temporary, Pride is Forever '96 yota T100 with 31x10.50 BFG all terrain tires, 4x4 automatic transmission |
#2 (permalink) |
Here is one on ebay that is $37.99 shipped. Says it's better than OEM.
http://cgi.ebay.com/ebaymotors/94-95...Q5fAccessories New plastic will be better than 13 year old plastic.
__________________
1993 T100 3.0L V6 3VZE 4x4 (47K) |
#3 (permalink) |
Are yer motor mounts bad? Can't see why yer blade would be hitting anything except maybe the shroud when you rev the engine.
#4 (permalink) |
thanks guys but i replaced the 13 year old 1 with a new 1. then it broke i need somethin tronger, any ideas?????
Thanks, Colten
__________________
#5 (permalink) |
sounds like you got something going on that is causing the blades to keep breaking. like Bam said, check your motor mounts and fan shroud to make sure that it isn't hitting any thing. my fan is 16 years old and is still going strong. however, it is possible that you got a new one that was defective.
__________________
93 T-100 3.0 5spd 4x4 high flow cat, custom duals 17" Powder coated Sequoia wheels 32" Mickey Thompson Baja ATZ tires stock lift new factory clutch- if you order from Downey, make sure you get the right one:( diff breather mod. cobra cb custom rear bumper w/tire carrier-Kennasaw Mtn. acc. In the works. light bar and hella 500's |
#6 (permalink) |
you gotta figure out why its breaking. A metal blade may bend from whatever is breaking yours and may cause other damage to your radiator or belts.
__________________
92 toyota truck 3.4 5spd 4.56 gears magna flow cat and muffler2 1/4 piping isr mod to intake 1.5 bjsfront add a leafs and 2inch lift shackles rear rancho shocks all around sitting on 265/75/r16 nitto terra grapplers |
#7 (permalink) |
X2 they are hitting something in order to break , But what?You need to find out .
__________________
'89 2wd X-tracab,W55,22re,My DD '94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD '88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907, XRC8, Homemade Roof rack.33x10.50,15 KM2 1" home made body lift, BJ spacers ,CB, rear disc brakes ,lockright rear.sky ebrake,truetrac front. My swap thread http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/ |
| Tags |
| 3vz, blade, blades, breaking, engine, fan, hitting, make, motor, mount, radiator, shroud, toyota, truck, trucks |
