CV Joint Replacement - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-04-2009, 09:08 PM   #1 (permalink)
I need to replace my cv joint on my t100. do i need n e thing besides the replacement joint?
Sloth21 is offline
Old 01-13-2009, 03:26 PM   #2 (permalink)
jsuthey's Avatar
Check my thread,I need some advice also! Is yours splattering grease?Not good! I have a haynes manual and it says you can but a reconditioned one?saves time but not $$? John
__________________
69 FJ40
93 FZJ80 RUBICON TESTED&READY!
98 T100 ext.cab 4WD
2000 4RUNNER LIMITED 4WD
jsuthey is offline
Old 01-14-2009, 09:54 PM   #3 (permalink)
Ya Its slpaterring grease a little. Its been like that for a cpl yrs. use to b my dads.
Sloth21 is offline
Old 01-30-2009, 10:58 PM   #4 (permalink)
I replaced my 2 front CV shafts, depnding on your year, and if you have 4x4 they simply just bolt on the transfer case and a little patience and they come right out, if you have the haynes manual iot makes it a lot easier.
ToyTruck98 is offline
Old 01-31-2009, 06:49 PM   #5 (permalink)
I've replaced CV Boots twice, but I now think it is frequently better to get a rebuilt half-shaft. If the outer-boot is leaking (most common) you end up replacing both boots (the outer comes off the inside end of the shaft). With the price of both boots you're getting close to the price of a rebuilt half-shaft, ready to go. Plus, replacing the boots is a dirty, messy job (you'll be messy anyway, cleaning up the old grease you've thrown all over the place). There are two kinds of clips that hold the boots on; if you already own one of the tools, your new boots will come with the other kind of clip!
But to replace a CV boot you must know the SECRET: support the wheel on a jackstand so that the suspension is fully retracted (just as it would be sitting on the ground). Once unbolted, the half-shaft can be wiggled out pretty easily. But if you leave the wheel hanging (by putting your jackstand under the frame, for instance), the angles are not right, and it WILL NOT come out. DO NOT pound out the studs, remove the ball joint, take off the shocks -- you don't need to do that if you know the secret.
__________________
1994 6cyl 4wd XCab -- all stock
scope103 is offline
Tags
1994, 80, boot, cv, fj, half, halfshaft, joint, pickup, remove, replacement, shaft, t100, toyota, wheretogetcvbootreplacedeastbay, yotatech, yototech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
u-joint replacement stephenmarr 95.5-2004 Tacomas & 96-2002 4Runners 7 09-21-2008 06:33 PM
U-Joint Replacement wormhole Arizona 15 08-09-2008 05:55 PM
U-joint replacement? wormhole Arizona 1 05-24-2008 02:31 PM
U joint replacement brendonv 95.5-2004 Tacomas & 96-2002 4Runners 0 11-04-2004 10:54 AM
U-joint replacement blank 95.5-2004 Tacomas & 96-2002 4Runners 4 09-03-2004 07:55 PM
2009 InternetBrands, Inc.
