Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Clutch Pedal Help
I have a 98 T100. I replaced the master cylinder and the slave cylinder about 4 months ago. Both were bled through with DOT 3 break fluid. The fluid was clean. I recently noticed that the clutch pedal gets stuck at times. It gets stuck when I start in, sometimes when I shift into first and sometimes when I shift into reverse. When I'm shifting through gears 2-5 its totally fine. Nothing looks like its leaking, all the fluid is still there. However the fluid looks dirty. When my engine is off, I can pump the clutch pedal and it returns fine, until I hold the pedal down. The pedal gets stuck and then eventually goes down to the floor. The bushings and springs look good and there doesn't seem to have any bracket damage. What could the problem be?
| Sponsored Links |
#2 (permalink) |
stuck like you pushed it to the floor and it didn't return or stuck as in you can't push ot at all? or do you push it partway and then stops before hitting the floor?
__________________
93 T-100 3.0 5spd 4x4 high flow cat, custom duals 17" Powder coated Sequoia wheels 32" Mickey Thompson Baja ATZ tires stock lift brand new factory rear axle housing, seals, brakes, everthing but origional axle shafts and third member. new factory clutch- if you order from Downey, make sure you get the right one:( diff breather mod. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Problem with clutch/clutch pedal | bpina4813 | 86-95 Trucks & 4Runners | 8 | 01-12-2007 08:38 PM |
| Clutch grinding, poor shifting, cracked clutch pedal bracket | T100NewMexico | 93-98 T100s | 10 | 09-22-2006 01:31 PM |
| Clutch pedal/clutch problem: help needed | p.m.coupe | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-04-2006 02:18 PM |
| Will the height adjustment of the clutch pedal affect the wear of the clutch? | YotaJunky | Maintenance & Repair Archives | 6 | 11-21-2005 08:03 PM |
| no clutch pedal | Longshot | Maintenance & Repair Archives | 7 | 04-22-2005 07:49 PM |
