93-98 T100s All T100 trucks
Clutch and 4x4 help please
Old 09-24-2012, 06:10 PM
Gunter92's Avatar
Ok for the clutch, I put new clutch in truck 3 months ago however I can push clutch all the way to floor and it is still hard to engage in 1st and this is from dead stop and then same thing happens when i first start off and try going into reverse, but then while driving going into 4th has a problem????
4x4 when i push lever into 4 hi or lo it goes into 4x4 but as soon as i start to drive it catches every few secs and make a loud clunk noise any suggestions on what to look at?
Any help is appreciated
Old 09-24-2012, 08:08 PM
justin_4runner's Avatar
sounds like the syncroids are bad for first gear and 4th, as for the 4x4 i would look at drive shafts, u can try bleeding the clutch again.
Old 09-25-2012, 07:18 PM
Gunter92's Avatar
Im going to probably pull tranny soon to look over, also do you know if parts of a early tundra would fit t100?
Old 09-26-2012, 06:33 AM
SC T100's Avatar
First replace the shifter bushing and ball with the Marlin Crawler units and see if that works. It has cured many of these issues for $25. Also check to see if you have the black clutch pedal bracket...it it's grey it may have cracked. Also check the firewall to make sure it hasnt cracked.
When the 4x4 is "catching" are you on pavement? Specifically, turning on pavement (like backing/turning out of a driveway)? Because if so that's normal and you are stressing the transfer case as the front and rear driveshafts try to spin at different speeds. If it's "catching" when you are on soft dirt/off-road there is another problem.
Old 09-26-2012, 06:50 AM
waskillywabbit's Avatar
Try simple things first.
Check pedal bracket for fatigue and cracks
Check MC and slave for leaks and functionality.
Check shifter bushing and seat.
:wabbit2:
Old 09-26-2012, 04:29 PM
Gunter92's Avatar
I will check this, and the 4x4 does it on dirt or anything and it consistently does it, it never stops until i take it out
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
PlayAwhile
07-20-2015 11:36 AM
1996Taco
07-20-2015 12:02 AM
Quick Reply: Clutch and 4x4 help please
