carrier bearing 96 T100
Any advice or knowledge on this subject is appreciated, My carrier bearing for my T100 has to be bad, it is an original part on my 222000 mile pickup, and it is sagging. Something is rattling and knocking in the drive train so I figured I would replace the U joints and bearing. It would have to happen sometime soon anyhow. the bearings I have been looking at all have a note on the order that it excludes four wheel drive. I phoned up Toyota and they said that they are listed differently and have separate part numbers. but with all my looking I cannot find a measurable difference or there is not one listed. I found a new bearing on eBay for 43.66 and Toyota wants 186.71. And I found one for 101.00 so does anyone have any input? my question is: is there a difference between the 2WD and 4WD drive shaft carrier bearings? by the way the part number for the 4WD is 372-30-35120. thanks in advance
chili
chili
Just did mine Got it from rock auto for around $75. Just use pb blaster for about a week to loosen up the bolts. Use a box wrench 14mm to get the drive shaft bolts loose you only need to loosen the bolts directly behind the bearing. remove the bolt inside the flange then change the bearing and use lock tight blue during re assembly.
Tcsdef
09-07-2015 11:17 PM
