93-98 T100s All T100 trucks
Beating a dead horse??
Old 03-15-2015, 06:49 PM
ej1618's Avatar
Ok long story short, I had to get a new set of heads for my 96 t100. Today I installed the new timing belt and attempted a test start before complete assembly. The timing marks are all spot on by the way. Anyway the engine acts as if it wants to start but refuses to fire up. Now there are about 3 million vacuum lines disconnected still. Also the nimrod "mechanic" had the timing pullies on the wrong heads so I had to switch them.
So to my question, will the vacuum lines cause it to not start? I only saw a notch in the cam pullies no dowel holes, I may have missed them. Do all cam pullies have pin holes for the dowel pin? I'm perplexed, this truck ran like a champ before I had these morons work on my truck. It just had a blown head gasket. Any advice would be fabulous.. Thanks in advance E
Old 03-15-2015, 07:17 PM
millball's Avatar
The air piping from the VAFM to the throttle body must be piped up tight or there will be no fuel. A safety feature that prevents fuel spills after an accident when the engine is killed with the ignition still on.
Old 03-15-2015, 07:39 PM
ej1618's Avatar
VAFM? I'm not sure I know what that is. I had to order a new vacuum switching valve today because the fired mechanic broke a port off.. I'll put this on hold until that comes in and get all the vacuum lines reconnected.
Old 03-15-2015, 09:00 PM
millball's Avatar
VAFM= vane airflow meter.
It is the electronic unit built into the top of the aircleaner box.
The large main air pipe runs between it and the throttle body.
smilen724
13
11-08-2015 04:11 PM
Chicken12
10-14-2015 03:54 PM
mreagen
10-05-2015 04:27 PM
89YodaRunner
09-30-2015 02:18 PM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: Beating a dead horse??
