YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-01-2008, 01:38 PM   #1 (permalink)
Back Up Lights?
My back up lights do not work. So my question is; where do the wires for the lights hook into the transmission? I think they might just be unplugged.
Thanks.
funnyguy44444 is offline
Sponsored Links
To remove this ad, register today!
Old 04-01-2008, 02:43 PM   #2 (permalink)
Do you have an auto trans? If you do, did you check the "Gauge" 10A fuse and the back-up light relay (it's a square one) located in the interior fuse box? Are you sure you checked both light bulbs and run current through them or did a continuity check? Did you check the harness? Did you check the backup switch?
BamZipPow is offline
Old 04-02-2008, 08:49 PM   #3 (permalink)
Its a manual not auto. The bulbs are good. All the fuses are fine. Haven't checked the harness or backup switch cuz i don't know where they are. That's what i was hoping to find out, what components are they hooked to and where those components are.
Old 04-03-2008, 06:54 AM   #4 (permalink)
It should be a 2 wire switch located on the side of the transmission.
The switch is a threaded type with a hex body.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
What do you use for back-up lights? steelydan General Electrical & Lighting Related Topics 21 12-20-2006 05:08 PM
I Have Back Up Lights Now!!!!! gohawks 95.5-2004 Tacomas & 96-2002 4Runners 1 01-16-2005 09:44 PM
back up lights lunatic14r 95.5-2004 Tacomas & 96-2002 4Runners 5 12-14-2003 11:25 PM
KC Back-Up Lights 4x4Fink 95.5-2004 Tacomas & 96-2002 4Runners 12 12-03-2003 02:36 PM
Back-up lights van.islandrunner 95.5-2004 Tacomas & 96-2002 4Runners 7 11-12-2002 05:32 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
