YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-22-2008, 08:28 PM   #1 (permalink)
randall's Avatar
axle shaft problems
how do i get my drive axles out of the front diff?
randall is offline
Sponsored Links
To remove this ad, register today!
Old 02-22-2008, 08:35 PM   #2 (permalink)
drew303's Avatar
There are snap rings on the ends of the shafts you access from the differential. Take em out should slide out.
check this out
http://personal.utulsa.edu/~nathan-b...23disassem.pdf
__________________
1987 Toyota P/U 4x4 pics/info
drew303 is offline
Old 02-22-2008, 08:44 PM   #3 (permalink)
toytech76's Avatar
you dont need to touch the snap rings. The shafts just need to be popped out. Sometimes they can be stubborn so use a long prybar and work around all edges of the shaft
__________________
97 Runner. 3" revtek front with 1/2 added spacer, front 97 LC coils and shocks in the rear, 33x12.5/15 Pro Comp mud terrains, 15x8 Pro Comp 1069 alloys, 00 runner headlites, clear corners and bumper lenses, 00 runner airbox/MAF conversion, Reverse indiglo gauges, 5000K HID's, LC hood struts, Magnaflow exhaust, custom grill insert, hella driving lights converted into headlight highbeams, retrofitted avalon homelink sunvisor.
toytech76 is offline
Old 02-22-2008, 08:47 PM   #4 (permalink)
randall's Avatar
right on
I got one side off but the other side is really stuck. After you get them out how do they go back in?
randall is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
3723035130 Universals & rear axle - Rear axle - Propeller shaft - Center bearing NEW xcmountain80 Misc Stuff (Vehicle Related) 0 12-10-2007 12:54 PM
Axle shaft bent? jarboarder1 95.5-2004 Tacomas & 96-2002 4Runners 4 10-26-2007 08:03 PM
axle shaft rear rebult junk 86-95 Trucks & 4Runners 0 10-11-2007 03:33 PM
88 axle housing.........90 axle shaft....Fit? Yoda Offroad Tech 1 12-10-2005 10:36 AM
Axle shaft Help Needed!! cabbage 95.5-2004 Tacomas & 96-2002 4Runners 8 04-11-2004 08:39 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
