YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-05-2007, 07:49 PM   #1 (permalink)
JM
Anyone know the size of the center pins?
I Have a couple of aal that I got free but did not get the center pins with them. I thought I could got to Home Depot and get some allen head bolts but I do not know the correct size. Can anyone help?
Thanks
JM is offline
Sponsored Links
To remove this ad, register today!
Old 06-05-2007, 07:57 PM   #2 (permalink)
WATRD's Avatar
It depends upon the spring.
http://www.suspensionconnection.com/...tion/to=r.html
__________________
-Rob
Slightly Modified 2001 Tacoma - WATRD.COM
WATTORA Prez
Tread Lightly certified Tread Trainer
I don't work here anymore... In fact, I seldom visit anymore. You can find me via the links in my signature.
WATRD is offline
Old 06-05-2007, 08:03 PM   #3 (permalink)
JM
Thanks for the link but that does not tell me the Toyota Tacoma factory center pin bolt size.
JM is offline
Old 06-05-2007, 08:08 PM   #4 (permalink)
WATRD's Avatar
Again, it depends upon the springs. Toyota uses at least two different sizes.
__________________
-Rob
WATTORA Prez
WATRD is offline
Old 06-05-2007, 08:12 PM   #5 (permalink)
JM
Thanks Rob. I did not know they use two different sizes. I guess I will have to remove one and match it up.
JM is offline
Old 06-05-2007, 08:14 PM   #6 (permalink)
WATRD's Avatar
That would be your best bet... or... post up the model and year and I bet someone can narrow it down for you
__________________
-Rob
WATTORA Prez
WATRD is offline
Old 06-05-2007, 08:28 PM   #7 (permalink)
JM
Well the model is a T-100 1996. Now I know what you are saying " Why did you post it in the Tacoma section". The reason is there is not to much on the T-100 section and I think the Tacoma and the Tundra/T-100 share some of the same rear lift parts.
I like my T-100 but there is very little on tech support and modifications.
Marc
JM is offline
Old 06-07-2007, 06:31 AM   #8 (permalink)
JM
Found out it is a 3/8 bolt. I used the 2 1/2 " x3/8 worked great.
JM is offline
Old 06-12-2007, 12:47 PM   #9 (permalink)
4Crawler's Avatar
Likely the Toyota bolt is actually 10mm, but 3/8" works fine. Also the AAL is probably drilled for the slightly smaller 3/8" bolt:
- http://www.4crawler.com/4x4/ForSale/...ml#CenterBolts
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Should I try the Wrist pins? or just a new block... Numbchux General Vehicle Related Topics (Non Year Related) 0 02-15-2007 11:51 PM
Removing Wrist Pins Bill 86-95 Trucks & 4Runners 2 02-13-2007 02:52 PM
Ever had pins to set a bone??? Nitro Hotpants Off Topic Talk 22 09-03-2005 10:46 PM
How do you and which pins to check codes? PirateFins 95.5-2004 Tacomas & 96-2002 4Runners 2 12-16-2003 09:39 AM
Pounding out pins Corey Maintenance & Repair Archives 3 08-27-2002 08:45 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
