YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 12-04-2007, 06:10 AM   #1 (permalink)
Any VSV??
Does anyone know if the "4WD control unit" AKA VSV's to control the 4WD actuator are universal to toyota trucks. In other words can I put the VSV of a '03 4 runner on a 95 toyota T100, since the ADD is more or less operating in the same way
reebbrew is offline
Sponsored Links
To remove this ad, register today!
Old 12-04-2007, 10:28 AM   #2 (permalink)
Dunno if the 03 4runner has the ADD, but any of the ADD rigs around the same vintage should work. I doubt the 03 runner has the same actuator. I may have my old unit laying around. It worked fine when I took it off, but I haven't seen it in awhile. I'll see if I can find it and post back.
__________________
94 FZJ80 fully locked, OME lift, 285s; 95 T100 beater edition; 1995 LS 400.
No problem, I'll tow the pig with a Uhaul Trailer...
"A vehicle's capabilities are inseparably linked to the mental instability of the driver"
Klierslc is offline
Old 12-04-2007, 01:20 PM   #3 (permalink)
4Crawler's Avatar
You would probably need to take a look at them to be sure. Might be connectors have changed, so may need to swap connectors. Might be the mounting brackets are different, so might have to make a change to attach them. But otherwise, should be the same basic feature/operation.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 12-04-2007, 02:04 PM   #4 (permalink)
OK thanks. I have found a few of them in scrap yards in my area but they were duds and did not work. I may try some other models of that era. At least i can get my 4 WD to turn on. and then I just switch the hoses to get the actuator to disengage. Kind of a pain in the rear but do-able for the winter season. I am thinkign about weather to get another VSV unit (used of course) or just simply lock the actuator "on" and going with mannual hubs. Any recomendations.
reebbrew is offline
Old 12-04-2007, 08:31 PM   #5 (permalink)
I took out the whole ADD system and went with manual hubs, but that was when I was using it for a wheeler. For normal use, I think the ADD is a lot handier than the manual hubs. OTOH, the ADD wears out CV shafts faster....
__________________
Klierslc is offline
Old 12-04-2007, 09:12 PM   #6 (permalink)
Froggy93's Avatar
I prefer my ADD in the winter time. would be nice to have manual hubs but with ADD all you do is pull the lever inside. no getting out in the cold and snow to lock the front hubs that hopefully still move freely. I would fix the ADD for now.
__________________
93 T-100 3.0 5spd 4x4 high flow cat, custom duals
17" Powder coated Sequoia wheels
32" Mickey Thompson Baja ATZ tires stock lift
brand new factory rear axle housing, seals, brakes, everthing but origional axle shafts and third member.
new factory clutch- if you order from Downey, make sure you get the right one:(
diff breather mod.
Froggy93 is offline
Old 12-04-2007, 09:16 PM   #7 (permalink)
4Crawler's Avatar
You can always just lock the front hubs when the snow starts to fly then shift in and out of 4WD as needed.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 12-04-2007, 11:36 PM   #8 (permalink)
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Although the 03 4runners did use ADD, they use an electric actuator, instead of vacuum actuator.
I believe vacuum stopped in 2000.
So, no, you cannot use an '03 valve in a 95. you can, however, use a 4runner or tacoma from model years 95-00 on it.
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by Junkers88 View Post
Good lord this thread is like herpes. Everytime I think it's gone there's another outbreak.
Quote:
Originally Posted by 1972TLC View Post
DC, you're always #1, don't worry ;)
DeathCougar is online now
Old 12-05-2007, 07:23 AM   #9 (permalink)
Thanks death couger that will help with the years on the "suck-tion" ADD. That may give me a few more vehicles to pull these out of.
reebbrew is offline
Old 12-26-2007, 09:34 AM   #10 (permalink)
Thanks DeathCougar
Thanks, I am looking for the same vacuum parts for my ADD on my '95 T-100.
The years of Tacoma and 4-runner will help in the search for parts.
jnaumann is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
vsv for cold start lonestar 86-95 Trucks & 4Runners 3 11-27-2007 12:38 PM
VSV help tnactsuj 86-95 Trucks & 4Runners 15 10-24-2007 03:21 PM
VSV and the FPU Elvota 86-95 Trucks & 4Runners 11 05-23-2007 08:37 AM
Tank Bypass VSV Jeebs 95.5-2004 Tacomas & 96-2002 4Runners 1 04-03-2006 09:34 AM
I need pics of 3.4L evap and vsv RBA 95.5-2004 Tacomas & 96-2002 4Runners 0 08-29-2004 09:25 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
