| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
94 t100 axle code
#2 (permalink) |
there no way it could be geared to 3:56
#3 (permalink) |
![]() this is my door sticker if it helps |
#4 (permalink) |
__________________
92 toyota truck 3.4 5spd 4.56 gears magna flow cat and muffler2 1/4 piping isr mod to intake 1.5 bjsfront add a leafs and 2inch lift shackles rear rancho shocks all around sitting on 265/75/r16 nitto terra grapplers |
#5 (permalink) |
no wonder my truck is so freakin slow, 3.58s with 31s!!!
i need some new gears asap!!! haha thanks so much vital |
#6 (permalink) |
heads up for next time... use the search function here, i typed in gear code and found that.
__________________
#7 (permalink) |
ive been using the search function, but i didnt type in gear code, i typed in axle ratio.
but thanks for your help |
#8 (permalink) |
I'm not sure about your door sticker or Brian's site, but my understanding for years now has been that all manual T100's came from the factory with 4.10's and all automatic T100's came with 4.30's.
Ask around on some more active T100 forums and I think you'll hear the same from other longtime owners.... .
__________________
'97 T100 ~ TRD SC ~ ARB ~ FWC '85 FJ6O ~ 4E9 ~ locked ~ 33's '87 Turbo 4Runner ~ sold |
#9 (permalink) |
I think the 4 cylinder manual transmission 1994-1998 longbed T-100s came with a lower gear than 4.10...at least that's what www.car-part.com sez.
I'd verify the gear ratio by ErikB's guide...
#10 (permalink) |
im so confused i dont know which chart to use
one says 3.36 and the other says 3.58??? ![]() all i know is it takes my truck like 30 sec to get to 60mph |
#12 (permalink) |
#13 (permalink) | ||
Quote:
The procedure is as follows...copied from this link that I linked on my first response... http://home.4x4wire.com/erik/diffs/#ratios Quote:
| Tags |
| 25, 4runner, automatic, axle, code, codes, decode, gear, ratio, ratios, search, t100, toyota, trans, truck, vin, yotatech |
