93-98 T100s All T100 trucks
1996 t100 3.4 sr5 problem
Old 05-19-2016, 06:00 PM
Peetachow's Avatar
My yota is having a problem with the motor cutting out at 3500 to 4000 rpm after a timing belt job, but i seem to think it is unrelated.we had it on a live data scanner and there were no misfires... what could possibly be the problem? it seems like it is hitting the rev limiter way too early is the best way to describe it.any help is appreciated
Old 05-24-2016, 03:41 PM
nataraj's Avatar
I would check the crankshaft position sensor and wires and make sure the big pully on the crankshaft (bottom one) is on tight and the key has not sheared. The engine will not run if it does not get the correct crankshaft position.
hektikwon
05-06-2016 07:16 PM
RadfordBeats
04-28-2016 08:08 AM
Murfy101
04-26-2016 04:10 PM
lvwilly
04-26-2016 09:06 AM
4by4yoter
04-23-2016 12:46 PM
Quick Reply: 1996 t100 3.4 sr5 problem
