Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
1993 T100 automatic trans same/compatible as 95 up for 3.4 swap?
Alright,I am planning on swapping in a 3.4 liter into my 93 T100, but my issue arises with the transmission (my truck obviously has the 3.0 liter). After doing some quite extensive research on this subject I have learned the manuals bolt up just fine, but the auto transmissions need to be swapped. This is at least what I read about concerning the 4runners and the compacts, but I seen somewhere else that the T100 automatic transmission is different.
My question is therefore, did the T100 have a unique transmission that made it compatible with the later produced 3.4 liter engine? Any help some Toyota experts can give me would be greatly appreciated.... Last edited by Ric18 : 12-21-2006 at 06:27 AM. |
| Sponsored Links |
#2 (permalink) |
Well I am buying a 3.4 and going ahead with it. I'll let everyone know how it goes...
I got the ECU and wiring harness as well... I was communicating with someone with a 1996 T100 and his has the exact same designation as mine... This is good news. |
#3 (permalink) |
good luck. post some pictures if u can. I am thinking about future swap ideas for my T100. in college now so can't afford it but maybe later. don't know about the bolt patterns on the trans though.
__________________
93 T-100 3.0 5spd 4x4 high flow cat, custom duals 17" Powder coated Sequoia wheels 32" Mickey Thompson Baja ATZ tires stock lift brand new factory rear axle housing, seals, brakes, everthing but origional axle shafts and third member. new factory clutch- if you order from Downey, make sure you get the right one:( diff breather mod. |
#4 (permalink) |
Do you know how much the 3.4 weights vs the 3.0. I have a 1993 4Runner w/auto and thinking of doing the same swap. I'll be keeping and eye on your post.
#5 (permalink) |
The T100 was equipped with the rare passenger side drop A340F (while 3.0's in 4Runners/trucks came with the A340H). I'm not certain of the reasoning, but I wouldn't assume the 96+ T100 has the same trans even though it has the same designation. I thought the reasoning for using a trans from behind the 3.4 was a wiring issue.
The good news is that with the A340F, you can easily add a crawler (before I'm corrected - yes I know Inchworm has a kit for the A340H, but it requires dismantling the trans/t-case)
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#6 (permalink) |
I could use some pics of that tranny and transfer case combo, I'm sticking a '97 3.4 into a '95 4Runner and need a transfer case with the correct drop
#7 (permalink) |
You can use a Marlin adapter and gear drive case behind any A340F. The adapter is for an auto to gear drive case - or you could go bananas and get a double too...
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Automatic Trans Trouble | cweich | 86-95 Trucks & 4Runners | 1 | 11-27-2006 02:30 PM |
| 1993 T100 Sr5 V-6 4x4 | PRNDL | Vehicles - Trailers (Complete) | 2 | 11-14-2006 01:37 PM |
| Automatic trans questions... | Vayhemar | 84-85 Trucks & 4Runners | 2 | 06-10-2006 09:27 AM |
| 1990 4Runner vs. 1993 T100 | 90!4Runner | 86-95 Trucks & 4Runners | 12 | 02-06-2006 05:57 PM |
| 22RE and 22R Head swap...compatible years? | Mudd Runna | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 04-13-2003 06:53 PM |
