Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Yet another set of rear floods
Just put in some rear floods. Got a set of KC HiLight rears for about 60 bucks from Summit.
Power supply from battery through fuse (here the rear yellow one): ![]() ![]() Through relay (looks messy now but other wires being moved!): ![]() Relay controlled by new OEM switch: ![]() Which is sourced off of Painless fuse block: ![]() Relay runs power out to lights. Used stock bracket, which fit perfectly on rear pan if you go towarsd outside edge, where very solid. ![]() ![]() These things put out more light than my headlights do! |
| Sponsored Links |
#2 (permalink) |
looks nice on the marlin bumper but i would smash those up, could you have mounted it on the top on the bumper?
__________________
1994 toy 22re- http://www.yotatech.com/f86/nocalsvx-s-94-toy-104593/ 2006 Subaru Forester XT -some mods/awd 5spd 1994 Subaru SVX- hwy runner 84 RX7- drag car build |
#3 (permalink) |
Yeah I could have but more work. Also, was a bit worried about clearance when dropping tailgate, plus I step up on bumper alot. Finally, the ground clearance is better than it looks from this angle, as I have an OME lift installed.
#4 (permalink) |
yea i seem to smash my marlin rear all the time, but i need somewhere for some more rear lights
see what i mean ![]()
__________________
#5 (permalink) |
Good stuff. My stockers are horrible, and only work 10% of the time. If you cleaned up your wiring then it all looks good
![]() You could also mount some round ones under each taillight, in that little pocket. Thats where I mounted mine on my marlin bumper.
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1980 floods out or sputters out???!!! | phreetogo | Pre 84 Trucks | 18 | 12-20-2007 09:13 AM |
| NW Floods!! pics! | mxrider8002 | Off Topic Talk | 40 | 12-08-2007 11:56 AM |
| WTB:A set of rear PP springs | manofsteele2003 | Items Wanted | 1 | 12-14-2006 05:34 AM |
| Rear shock length set up | Magreger | Offroad Tech | 1 | 05-23-2005 12:09 AM |
