YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-05-2008, 06:25 AM   #1 (permalink)
Would two alarm LED's significantly drain battery?
I have the factory RS 3000 alarm with the flashing LED status monitor in a 1998 4Runner. I recently upgraded the radio trim piece from a later model which also includes an alarm LED. My question is would having two flashing LED's drain the battery say if the vehicle wasn't driven during a two week vacation. I'm no expert on car electrics and apologise if this is a dumbo question.
__________________
Wanted: Square end caps for dark tan 4Runner cargo cover.
Wanted: 96-98 4Runner Clear bumper lights.
blarchitect is offline
Sponsored Links
To remove this ad, register today!
Old 06-05-2008, 06:30 AM   #2 (permalink)
AxleIke's Avatar
I wouldn't worry about it.
LEDs are used because they draw a miniscule amount of power to operate. I would be willing to bet that you couldn't drain a good car battery down with two LED's in two years. You'll be fine.
Now, that is assuming that you have nothing else in the alarm drawing power. As long as its just the LED's, you'll be fine.
__________________
IFS SAS
My mods aren't bling enough for the signature line.
-All Terrains are for when you know how to drive.
AxleIke is offline
Old 06-05-2008, 06:33 AM   #3 (permalink)
bigtrucknwheels's Avatar
Send a message via AIM to bigtrucknwheels
Quote:
its quite alright, the only way to know is to ask. you will be fine with those two LEDs, they wont drain your battery out, esp not in two weeks. they have a current draw in the miliamps or smaller area, which is about as much as your 4Runner consumes to remember user settings and data, such as the clock and the ECU. if it dies, and it was purely because of the LED's, then either you got something wrong elsewhere or you left a light on without knowing.
best of luck, and enjoy your vacation!
__________________
Left Wing, Right Wing, its all the same bird...
1990 Toyota 4Runner SR5 V6. 4wd/V6/Auto. Complete Part Out! Click or PM!
1990 Toyota Pickup Xtra Cab DLX. 4wd/V6/Auto
1989 Toyota Pickup Std. Cab DLX. 4wd/I4/5spd. FOR SALE SOON!
bigtrucknwheels is offline
Old 06-05-2008, 06:43 AM   #4 (permalink)
Thanks for the confirmation guys.
__________________
Old 06-07-2008, 08:22 PM   #5 (permalink)
deserttoy84's Avatar
Send a message via AIM to deserttoy84
think about this... those NINE led flashlight can run off 3 AA batteries for HOURS and HOURS!!
__________________
1984 toyota sr5 4x4
22r w/ weber 32/36
Pro comp 4" front springs and 3" rear downey springs
D-tech Shocks
33x12.5 M/T , 15 inch weld rims
Hella 550/ Hella h4 conversions with HID
Home made On-board air system
deserttoy84 is offline
Old 06-09-2008, 11:42 AM   #6 (permalink)
All academic as I plugged the original LED back in and the new one on the console stopped working. I can only assume that the alarm ECU can only send a pulsed signal strong enough for one LED??
__________________
Old 06-09-2008, 12:48 PM   #7 (permalink)
Staff
aviator's Avatar
That is a posibility though it may be that the box is only looking to flash one led. are these leds wired in series or parallel? in series the resistance of the first led is taking all the signal power. If they were in parallel they both might flash but at a slower rate.
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0
K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler
custom covered SR5 seats, map lights, factory AC
tv4184 style black interior conversion started
mods to come... header,
custom centre console, stereo upgrade
tinted windows
Founding member 1972TLC fan club
Toyota Hilux... Get in or Get out of the way.
aviator is offline
Old 06-09-2008, 01:45 PM   #8 (permalink)
Quote:
Mmm my electrical knowledge is lacking here! Would need to do some Google to find out diff between series and parallel. What I did was tap into the two wires feeding the original before the existing LED . Although the new connection is first it goes out when the the original is reinstated.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
DEI alarm= battery drain TACOMANATOR Vehicle Audio & Home Entertainment 4 11-07-2005 05:11 AM
HELP! Battery drain! Sporin Maintenance & Repair Archives 10 07-01-2005 05:24 AM
will i drain the battery? InFlames 95.5-2004 Tacomas & 96-2002 4Runners 6 06-06-2005 10:35 PM
Mysterious battery drain deadrunner 95.5-2004 Tacomas & 96-2002 4Runners 10 10-21-2003 07:40 AM
Need help...battery drain rpeAMP 95.5-2004 Tacomas & 96-2002 4Runners 3 11-05-2002 01:14 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
