wiring my inverter - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-15-2009, 08:08 PM   #1 (permalink)
wiring my inverter
so i just got a 800 watt inverter and unfortunatly all it comes with r little two foot power chords with alligator clips on the end to conect to the battery. the wire is 8 ga and my question is can i run about 10 or so feet of 8 ga wire to the battery and just ground in the cab where i want the inverter? or would 10 ft be too long of a stretch for the 8 ga and where do u buy 8 ga wire?
skibum707 is offline
Old 09-16-2009, 07:11 PM   #2 (permalink)
Staff
aviator's Avatar
Here's a link for you http://www.yotatech.com/f115/wiring-...verter-191576/
8ga may be a bit too small for you it depends on how much draw you are going to put on that 800W inverter and how far away from the batt. you plan to mount it. At a min. I would use 6ga and 4ga would be even better the wiring will run cooler with less resistance and the inverter will work better also.
Remember unless it a sealed marine rated unit inverters really don't like to get wet so pick a dry location.
You can get the wire from almost any HD or Lowes or an Electrical Wholesaler... Wiring with finer strands will be more flexible and easier to route through the body/frame then wiring with heavier strands. Protect the wire where ever you go through a hole in the body/frame with a grommet or piece of bicycle inner tube sleeved and zip tied around it to prevent chafing.
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0
K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler
custom covered SR5 seats, map lights, factory AC
tv4184 style black interior conversion started
mods to come... header,
custom centre console, stereo upgrade
tinted windows
Founding member 1972TLC fan club - Get well soon Mary
Toyota Hilux... Get in or Get out of the way.
aviator is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
