General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Window motors work, but switch does nothing?
Old 02-05-2016, 10:40 AM
FinallyOffRoad's Avatar
I can't put my windows down, but I know the motor works, because I took a battery straight to it and put the windows down, but for some reason neither of the switches will do anything. Is there a fuse to the power windows? Or some main power wire to the windows that might be cut or something?
Old 02-05-2016, 01:43 PM
wyoming9's Avatar
Red face
Are you talking the rear hatch window ??
The windows in the doors??
There is a window lock.
In my 92 4Runner the drivers door switch needs to be open.
Old 02-05-2016, 08:43 PM
Sorry no, it's the door windows. The window lock is not on. Unless the switch is messed up and it constantly on even when not pushed in.
Old 02-06-2016, 01:18 AM
wyoming9's Avatar
Red face
Just what year are you working on??
Has the vehicle sat for a long time switches do corrode
Depending what year your working with most all windows are powered through the door relay if that is not working .
Do the door locks work??
This is one of those things break out the Meter .
It can by any one of several things
Bad grounds, broken wires poor or unplugged connections
Old 02-06-2016, 05:18 AM
It's an '88. The door locks do work. I'm not sure if it sat around for a while, I just got it a couple weeks ago and am going through it trying to fix all the problems the previous owner caused.
MBOS4x4
02-06-2016 08:19 AM
FinallyOffRoad
02-04-2016 11:20 PM
kauaiaxel
02-03-2016 09:18 PM
AKrambler
02-01-2016 08:17 AM
yotajakes
01-30-2016 07:49 AM
Quick Reply: Window motors work, but switch does nothing?
