Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
turn signals
my front turn signals quit working first the pasenger side one then a few mins later the drivers side one, bulbs are good and fues are good, rear turn signals work just fine, any sugestions?
| Sponsored Links |
#3 (permalink) |
Check for power and ground at the actual light bulb sockets and if not present, work your way back to the connector and wiring back to the flasher relay. Might be a ground connection came loose up front.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#4 (permalink) |
the rear still work? They blink faster than normal?
__________________
1988 4runner::SAS|3vze|A340H|5.29's|Aussie Front|LockRight Rear|Longfield axles/Hub Gear|4"Rear/3"Front springs|Marlin High Steer|Custom CV rear driveshaft from High Angle Driveline|Rear D/S shortened and made into front D/S |35" Goodyear MT/R My 4runner n stuff |
#5 (permalink) | |
Are you getting power to the plug? If so, then look at the bulb bases. I had this same problem, and it ended up being corrosion in the bulb socket. Cleaned it out, and it started working again.
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts! Quote:
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Corner turn signals | Ritzy4Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 12-22-2007 10:10 AM |
| 99-02 turn signals | lee | Misc Stuff (Vehicle Related) | 1 | 04-25-2006 06:06 AM |
| Clear turn signals. Where to get them. | cccp | 95.5-2004 Tacomas & 96-2002 4Runners | 16 | 03-28-2005 10:43 AM |
| '89-'95 turn signals on a '90 4Runner? | DH6twinotter | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-13-2003 08:12 PM |
| Turn signals | data | Maintenance & Repair Archives | 6 | 08-03-2002 12:51 PM |
