General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Truck won't turn over unless connected to charger
Old 10-06-2011, 06:01 AM
Yotamonstah's Avatar
I've got an 87 4x4 Toyota, and she wont turn over unless I hook up the battery charger to it. I replaced the alternator, battery should still be good(red top optima) , I cleaned the battery terminals and cleaned all wires touching the terminals. any suggestions? thanks!
Old 10-06-2011, 06:13 AM
James Woods's Avatar
Get a multi meter and check for voltage drops, I had to replace my wife's cable ends because they were both cracked but looking at them they looked fine, voltage drop showed that the cables themselves were getting less than 10 volts.
Old 10-06-2011, 09:21 AM
Sensei's Avatar
^^x2^^ Also, how do you KNOW your battery is good. Being a red top doesn't mean squat. They fail just as bad as conventional batteries. Load test your battery using your meter. The meter should not drop below 10 volts.
Old 10-20-2011, 09:05 AM
turns out the starter was bad, she runs great now!
GreenLion
06-07-2021 10:49 AM
gillesdetrail
11-19-2019 12:56 PM
Cesarl74
04-23-2016 06:07 PM
alfonz33
9
11-16-2015 09:21 AM
odonekanobe
06-26-2015 02:27 PM
Quick Reply: Truck won't turn over unless connected to charger
