Tachometer Retrofit - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-08-2009, 10:15 AM   #1 (permalink)
Tachometer Retrofit
Greetings All,
I'm wanting to add a tach to my little baseline 93 pickup. In examining wire harnesses (and for that matter the flexi pc board on both styles of inst clusters) - they "appear" identical across the board - both models have 4 molex style connectors and as near as I can see - the same number of active pins and so on....
Question(s) is there a proper clock pulse present in a baselines models wiring harness to allow a simple "swap" of a baseline inst cluster for a deluxe one? - or do I have more work cut out for me? Also, is the gauge calibration internal or external (i/e - can I use a cluster from a v6 model in a 4 banger??)
Any sage advice (preferably from ones that have "done" the work vs those who are armchair dreamers)? And on the subject, would the other gauges function properly (i/e oil pressure vs just the idiot light) or would I need to change the transducer in the block too?
I'll save my air conditioning upgrade questions for now - as in studying "that" it appears the harnesses are different and I will be up for a bit of a challenge...
Cheers!
Jack King
speakernut@yahoo.com
speakernut is offline
Old 11-08-2009, 10:24 AM   #2 (permalink)
WatsonToyota's Avatar
the sr5 cluster swaps right in, problems arise with the oil pressure gauge tho, try searching this site to see what thousands of "arm chair dreamers" have done...
__________________
CURRENTLY IN TOYOTA REHAB
...previously owned...
88 4-runner 3VZE auto
94 pickup 22re 5 speed
WatsonToyota is offline
Tags
retrofit, tachometer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
