YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-15-2008, 08:01 PM   #1 (permalink)
Swansen's Avatar
Send a message via AIM to Swansen Send a message via Yahoo to Swansen
Tac light goes out when lights turned on
88 PU, its an aftermarket tac, but this just started happening after the fuse blew for the running lights and dash lights. So when the lights are off the tac works, but when i turn the lights on, it doesn't illuminate and stops working.
Swansen is offline
Sponsored Links
To remove this ad, register today!
Old 07-15-2008, 08:28 PM   #2 (permalink)
rowdy235's Avatar
something internally in the tach? Only thing that makes sense to me.
__________________
Daily Driver: 1982 Toyota Pickup Base 2WD 22R, TRD Cam,5-sp Manual, Toyota Truck Nation High Miler- 300k+
MPG: 25/32
Off-roader: 1990 Honda H3011SA Riding Lawnmower, 11hp OHV engine, Carlisle SNOW-HOG Tires
MPG: 1 Day of "Wheeling" per gallon
Come to the 2nd Annual Oregon Yotatech Meetup!
June 26-29, 2009: Browns Camp OHV Park
http://www.yotatech.com/f5/oregon-yo.../#post50902592
rowdy235 is offline
Old 07-15-2008, 09:47 PM   #3 (permalink)
4Crawler's Avatar
Check your wiring, most after market gauges are wired to have a positive wire for the light and the bulb is grounded to the case of the gauge (i.e. tied to the vehicle ground). The dash lights are wired with a floating ground which goes through the dimmer (rheostat) to let the dash light intensity be adjusted. If you tie a hard grounded device into the dash lights (with a floating ground), things like that can happen. Best bet it to tie the tach into a separate circuit (that switches on and off with the ignition) and if you want the back light to turn on and off with the lights, hook it to something like the parking lights, not to the dash lights. It won't dim, but you can add an in-line resistor if the light is too bright.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-16-2008, 05:43 AM   #4 (permalink)
Swansen's Avatar
parking lights??? i don't know if i have a circuit for that, as its a manual, unless i'm mistaken what you mean by parking lights. It said in the manual to have a good clean ground. So i just ran a separate ground straight to the battery. Everything else is wired in with the head unit. On that, it has an illumination, positive, negative, and signal leads.
Swansen is offline
Old 07-16-2008, 06:21 AM   #5 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
ok to turn on your headlights you twist the lever so it clicks twice, right? turn it once. when your brakelights and marker lights are on. thats what hes meaning. wire it into those lights.
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22RE 258,000 miles on original motor
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 07-16-2008, 06:33 AM   #6 (permalink)
zlathim's Avatar
Quote:
Originally Posted by ozziesironmanoffroad View Post
ok to turn on your headlights you twist the lever so it clicks twice, right? turn it once. when your taillights and marker lights are on. thats what hes meaning. wire it into those lights.
Fixed it for you.
__________________
Do you think Einstein walked around thinking everyone was a bunch of dipsticks?
Idiocracy (edited for family friendly viewing)
zlathim is offline
Old 07-16-2008, 07:06 AM   #7 (permalink)
4Crawler's Avatar
Quote:
Parking lights pr running lights is what I think you called them. The orange ones up front and the red ones in back that come on before the head lights.
What is the head unit "illumination" circuit hooked to?
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-18-2008, 04:59 PM   #8 (permalink)
Swansen's Avatar
Yes, so i am thinking it might just be the tac. I haven't jumped very far into the wiring, but my head unit it wired into the illumination lead that comes from the trucks wiring harness for the radio. On that, i noticed while driving today that it was stuck at 2,000 RPMs, so thats why i am guessing its the tac??? but i just check and it went back to rest. I don't know, but its weird that the tac is reliant at all on the illumination lead, i shouldn't even have to have it hooked it, all it should need is a signal, power and ground. hmmm... i wonder if i'm not getting a clean 12v, i guess i'm going to have to invest in a volt meter.
Swansen is offline
Old 07-18-2008, 05:21 PM   #9 (permalink)
4Crawler's Avatar
Tach may have a backlight but should work without that hooked up (just hard to read it at night). Volt meters are inexpensive (under $5):
- http://www.harborfreight.com/cpi/cta...emnumber=92020
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-19-2008, 11:59 PM   #10 (permalink)
Swansen's Avatar
Right, well, haven't gotten a volt meter yet, but i observed something weird. When the lights are turned off the tac is illuminated ????? thats confusing to me. So, what i am confused about right now is, why it worked fine before the fuse blew, but now the illumination is backwards??
Swansen is offline
Old 07-22-2008, 06:29 PM   #11 (permalink)
Swansen's Avatar
Turns out, it was a bad ground, the connection was loose, on a side note there should be a "solved" button for threads.
Swansen is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
I am getting a slight humming over the radio when the lights are turned on. noclueabout4runner General Electrical & Lighting Related Topics 6 04-15-2008 10:33 AM
Lights on HELP.. trans light, charging light, and brake light krash2k77 General Electrical & Lighting Related Topics 3 04-16-2007 06:20 AM
best year of 4th gen tac? A'sfan 95.5-2004 Tacomas & 96-2002 4Runners 4 07-16-2006 03:57 PM
Starter 98 tac ? txtony Maintenance & Repair Archives 1 09-11-2005 05:47 PM
99 tac lift kit bamayote 95.5-2004 Tacomas & 96-2002 4Runners 3 11-01-2003 07:37 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
