| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) |
the white button should be for starting/ should not start if not pushed in. Are you getting fire to the relay under the hood, and have you ran a jumper from your battery to the starter to test it.
__________________
85 toyota rancho lift 33 in tires on 15X8 steel 270 lift cam and flat tops Those who do not learn from history are doomed to repeat it, or they're showing up their friends. Again! |
#3 (permalink) |
I wasn't getting anything from the harness that plugs into to start relay. Thats why I thought about starting at the ignition switch and working from cab to under the hood. Thats when I came across that relay by the glove box. Yes I tested the starter on the ground, but I haven't since I put it back on the motor, which actually would be a good idea so I can make sure my block is grounded.
#4 (permalink) |
See below for some info:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#5 (permalink) | |
I'm going through it too. I went to Kragen last night and couldn't find a relay anywhere. Maybe a car stereo place will have/sell them. Or Radio Shack? There is a few good how-to videos on different ways to use a relay on youtube.
__________________
'85 4Runner totaled and brought back 22RE-C 5spd 4.88's, Rear IFS axle with Detroit Locker and Tru Trac up front Doug Thorley Header and LC Engineering Cam, K+N, Downey 3 inch leaves and Rubicon shackles with Pro Comp shocks 32x11.5-15 BFG AT's Quote:
#6 (permalink) | |
Quote:
- http://www.4crawler.com/4x4/CheapTri...shtml#HOrelays
__________________
