YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-30-2007, 09:43 PM   #1 (permalink)
Stupid mistake = No Power
Tonight I was trying to install a Optima Yellow top battery into my 4 runner. I removed the old battery and while talking on the phone to a friend I tried to install the new battery. I wasn't paying attention and installed the Optima backwards. I connected the + to the - terminal and vise versa. I saw a spark but thought nothing of it at the time. I went to check things out and I have no power whats so ever in the cab. The only fuse that I can see that is blown is the 100 amp alternator fuse. Is this the location of my power problem and how easy is this to replace? It is dark out and I don't have a garage so I am struggling to locate any other issues. But while trying to remove the fuse the two legs seperated from the fuse housing and stayed in the fuse box while the cover came out. What do I do now? I am new to electrical issues and am in need of help. Any info would be greatly appreciated. Do I need to look elsewhere for issues as well? Could I have fryed the new battery?
AZRedneck is offline
Sponsored Links
To remove this ad, register today!
Old 05-30-2007, 09:46 PM   #2 (permalink)
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
that 100 amp fust is the main power to the whole truck. Replace that fuse, all should be good...and thank your lucky stars you didn't break anything else.
BTW That fuse does not pull out the top. It slides out the bottom, and is actually bolted to the wiring with 10mm and 8mm (wrench size) bolts. DONT try to pry it out the top, it will only damage your fuse block. You have the press a clip aside, then slide it out the bottom.
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by Junkers88 View Post
Good lord this thread is like herpes. Everytime I think it's gone there's another outbreak.
Quote:
Originally Posted by 1972TLC View Post
DC, you're always #1, don't worry ;)
DeathCougar is offline
Old 05-30-2007, 10:23 PM   #3 (permalink)
Thanks for the info. Is it difficult to get to the underside of the fuse block? Do I need to worry about anything else when I go to remove the top of the fuse block? I have to fly out of town tomorrow for the weekend and will not return until sunday late night. Can I get this fuse at any auto parts store or do I need to get it from toyota? Could I have damaged the Optima battery? I also read that if the battery is disconnected for to long that there could be an issue with the air bag sensor or something to do with the air bags not functioning correctly. Could this be an issue I will have to deal with?
Old 05-30-2007, 10:27 PM   #4 (permalink)
lemme stop for a sec....what year is your 4runner? Im talking first gen heh. I have 4runner on the brain.
Either way, you DO have to press it down and out of the block regardless of the year it is, and its attached with bolts, no matter what year it is.
__________________
Old 05-30-2007, 10:37 PM   #5 (permalink)
Sorry i should have stated that. It is a 98 4runner.
Old 05-31-2007, 09:25 PM   #6 (permalink)
My brother made this same mistake with my dad's 95 Runner. I ended up replacing the fuse you are talking about.
Anyway, after replacing the fuse and getting the truck to start, the two map lights under the rear view don't come on, the radio doesn't come on, and the dome light doesn't come on. All of which blows cause I hate electrical. I hope this didn't happen to you after fixing the starting issue.
Santerianumero1 is offline
Old 06-01-2007, 09:45 AM   #7 (permalink)
Well I got the 100 amp fuse replaced yesterday before I had to fly out of town for a wedding. The dash lights came on but that seems to be it. I did not try to start the motor just because I have a lot of other stuff in pieces right now in the engine bay. However, my dome light doesn't work and my electric door locks weren't working. This was all I had time to check out before I had to go. My alarm did work but it wouldn't run the locks either. Could this be due to a fuse or a computer problem? I will hopefully have some more time the first of next week when I get back in town. Hopefully it is just fuses and not something else. Any info on this would be greatly appreciated. Thanks for all the replies.
Old 06-01-2007, 09:08 PM   #8 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
I would guess you blew some other fueses... there is also a fuse block inside the truck, check there.
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 6 Spd, Pricol EGT and boost, 2" Level, Jake Brake, Muffler Delete, filtered, lubed and bypassed by Amsoil, Mag-Hytec Rear, Fast Coolers, Baldwin 7977, Smarty JR SW#1, Toyo 285's...
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 06-05-2007, 08:53 PM   #9 (permalink)
Well I checked all the fuses and only found 1 that was blown. It works with the dome lights and continues to blow fuses. There has to be a short somewhere. I have no automatic door locks and my radio doesn't seem to work. I also get two clicks from the passenger side engine compartment when I turn the ignition to the farthest point before it turns over. I have never noticed this before. I am begining to think I need to take this to a mechanic but I am afraid of the charges. Electrical issues are never cheap from my experiences. Anyone have any ideas.
Old 08-19-2008, 11:25 PM   #10 (permalink)
annoyingrob's Avatar
I can't remember, but do these trucks run fusable links too? If so, check those.
Edit. Sorry, I didn't realize this thread was over a year old.
annoyingrob is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
stupid 3.4 power steering pump question BAMF_CT2004 95.5-2004 Tacomas & 96-2002 4Runners 2 06-29-2007 05:40 AM
Stupid Mistake...Now trouble shifting. 4runnersurf General Electrical & Lighting Related Topics 3 06-10-2007 05:20 PM
Stupid, stupid, stupid (I hope I found source of front end noise anyway) navyredneck 86-95 Trucks & 4Runners 1 10-28-2006 08:01 PM
Stupid mistake w/ battery ktmrider37 95.5-2004 Tacomas & 96-2002 4Runners 14 09-18-2005 07:23 AM
Help Wiring Mistake? guinness 95.5-2004 Tacomas & 96-2002 4Runners 0 04-01-2004 06:35 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
