YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-24-2008, 07:53 AM   #1 (permalink)
83
83's Avatar
SR5 Gauge Swap
Hey, I got a dash & instrument cluster from an SR5 truck. Mine is non-SR5. I don't see any wires with the cluster..thought I told the guy to include them, but oh well. Do I need wires from it to connect everthing up, or is it all in my truck already, just needing to be connected to the gauge? Also if anyone's done it and has any advice, I'd appreciate it. I got a write-up of the numbers & wire colors for the swap, but that's it. Thanks!
I'll go ahead and post what I have in case it's helpful to anyone.
SR5 non-SR5 wire color function
1 1 GY Right turn signal indicator
3 3 BR (B BR) Speed sensor (-) ground
4 6 GL Speed sensor (+)
7 23 YG Water temp gauge
8 9 RW Panel lights (+)
9 15 YR Fuel Gauge
10 12 Y Ignition switched power
11 21 YB Oil Pressure switch (idiot light)
12 22 YW Charge (idiot light)
13 14 WB Ground
14 Tach input - must be wired to igniter
yellow
15 17 GB Left turn signal indicator
16 16 RB Panel lights (-)
17
18
19 11 G 4WD
20
21 19 BY Seat belt
22
23 13 RG High Beam
24 20 GW Brake
For some reason it's not spacing out the way I'd like, but the first row is SR5 numbers, the second is non-SR5, third is wire color, fourth is function, in case it doesn't make sense.
83 is offline
Sponsored Links
To remove this ad, register today!
Old 06-24-2008, 07:57 AM   #2 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
everything is plug and play except for the oil pressure sender. and depending on how your truck is wired, you may have to run a tach wire
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22RE 258,000 miles on original motor
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 06-24-2008, 08:53 AM   #3 (permalink)
83
83's Avatar
Ok, thanks. So if he didn't give me any wires with the cluster, I'm ok with the wires in my truck already? I don't need to find a wireing harness (aside from the tach depending on my truck)?
83 is offline
Old 06-24-2008, 08:57 AM   #4 (permalink)
ur fine. just remember to change out the oil pressure switch with the oil sending unit
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 06-24-2008, 12:25 PM   #5 (permalink)
83
83's Avatar
Cool, thank you.
83 is offline
Old 06-27-2008, 08:58 AM   #6 (permalink)
83
83's Avatar
Now......Um.........so, if someone were to want to change the odometer.....how would such a person do that? Of course it's illegal and of course no one would do this, but say you swapped instrument clusters, I mean if you're actually trying to return the odometer to what the truck has on it....would that really be wrong?
I can't say that I want my odometer to read what the donor truck had on it, and even though having it start at zero sounds kinda cool (especially since my engine and transmission will be rebuilt), I'd prefer it said my actual mileage.
Anybody heard of how this might be done, just hypothetically, of course.
83 is offline
Old 06-27-2008, 10:42 AM   #7 (permalink)
874runnersr5's Avatar
Put it on blocks and drive in reverse
all jokes, i just had to say that. lol
__________________
87' 4runner Sr5 : 22re : 5spd : 32x11.5 Bfg mudterrains : Sirius radio :
coming soon: Downey 2" leafs : Bj spacers
I <3 my toyota
874runnersr5 is offline
Old 06-27-2008, 11:00 AM   #8 (permalink)
find someone who knows how to take apart the assembly, then have them set the mileage to what your truck has on it. i have yet to do this, in fact im kind of thinking of putting my dlx cluster (big speedo) back in...
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 06-27-2008, 11:30 AM   #9 (permalink)
83
83's Avatar
Ok, thanks. I'll see if I can find someone who will do it.
83 is offline
Old 07-07-2008, 07:39 AM   #10 (permalink)
83
83's Avatar
What's the deal? Everyone I've talked to says that the 79-83 instrument panels are all interchangeable............Have a look.
Is there any way to make this work, or am I back in the market for an instrument cluster? The top cluster is the one out of my truck, an '83. The lower is out of an '82 and I'd sure like to get it in my truck..
83 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
sr5 gauge swap question b82ta3 General Vehicle Related Topics (Non Year Related) 5 04-10-2008 01:09 PM
Doing the SR5 Gauge Cluster Swap deserthound 86-95 Trucks & 4Runners 0 03-21-2008 04:00 PM
SR5 gauge swap yota_dude 86-95 Trucks & 4Runners 3 11-15-2007 01:50 PM
sr5 gauge swap mwilliam13 Vehicle Audio & Home Entertainment 0 09-27-2007 04:58 PM
Those who have done the sr5 gauge swap.... Krash 95.5-2004 Tacomas & 96-2002 4Runners 0 12-05-2003 11:47 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
