Rusted out battery box need Ideas on how to replace or fix! - YotaTech Forums
Go Back   >
General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
LinkBack Thread Tools Search this Thread
Old 12-06-2011, 09:33 PM   #1
Link182's Avatar
hey all, So on my 89 pickup my battery box is pretty toast. the owner before me must have had a bad battery in the truck because the battery box it damn near completely rusted out. not even a stock battery will fit properly, so i have jimmy rigged it up. any ideas on what i might do to repair or replace it short of buying a whole new inner fender well? if you would like pictures let me know! thanks!
Link
Link182 is offline   Reply With Quote
Old 12-06-2011, 10:28 PM   #2
dsal_86Yota's Avatar
Cut out bad metal and replace with new metal
dsal_86Yota is offline   Reply With Quote
Old 12-07-2011, 08:06 AM   #3
Nervo19's Avatar
If you don't have access to a welder you can use rivets or sheet metal screws to attach some new metal. Cut out the rusty area and treat the area with rust proofer. You can cut a piece of steel from a junkyard vehicle or buy a small sheet of steel from Home Depot. It's pretty cheap. I've also seen someone use an old cookie sheet cut to fit. The battery will hide it anyway.
Nervo19 is offline   Reply With Quote
Old 12-11-2011, 02:59 PM   #4
Link182's Avatar
ok thanks man. I ended up going to a junk yard and finding a good inner fender well from an 87 toyota, with its original battery box intact. im gonna cut and weld that up to my truck. ill post some pictures when im finished to help others.
Old 11-09-2014, 08:40 PM   #5
did you ever take those pictures? im having the same issue in an 84 and want to see a little process work. what specs on the piece of metal would you suggest thats going to be durable for another 10 or so years?
DBD x509x is offline   Reply With Quote
Old 11-10-2014, 03:43 AM   #6
BigBluePile's Avatar
I'm sure that three years ago yes...
BigBluePile is offline   Reply With Quote
Void Dwellers 1995 4Runner 4WD SR5 voiddweller 86-95 Trucks & 4Runners (Build-Up Section) 19 05-02-2016 10:10 PM
Why is Battery Leaking? bigblue82 General Electrical & Lighting Related Topics 10 07-06-2015 09:27 AM
Water Leaking Behind Dashboard GorgeRunner 86-95 Trucks & 4Runners 8 06-27-2015 08:01 AM
Electrical (earth?) problem 1994 22r Taz22R 86-95 Trucks & 4Runners 9 06-21-2015 05:44 PM
Tags
4x4, batterie, battery, box, compartment, completely, corroded, ideas, repair, replace, replacing, rusted, rusty, toyota, tray
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
