YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-11-2008, 12:51 PM   #1 (permalink)
Yopar's Avatar
Power for when IGN is OFF
Does anyone know how to wire up an LED light so it's ON at all times, except for when the vehicle is running? I think a relay can be used with a signal from the IGN to kill the power to the LED when the truck is running, but I'm not sure how to do it. Any ideas?
If you're wondering why, this is for an "alarm" blinking LED that I want to be on unless I'm driving; also, I don't want a switch for it, rather it be automatic.
__________________
'87 4runner: fresh 22RE .020, 261c, OME springs/shocks, SDORI, relaxed Ts, 4.88s, front Lockright, marlin 1200 clutch, 16" Tacos, 255/85 bighorns, LCE header, magnafloW
"The Federal Reserve pretends to fight inflation but actually creates it. Inflation is the most insidious tax of all." --- ABOLISH THE FED
Yopar is offline
Sponsored Links
To remove this ad, register today!
Old 05-11-2008, 01:16 PM   #2 (permalink)
rowdy235's Avatar
Get a normally closed relay. Tap in to the "on" circuit, ground the other switch post, then run a wire from the battery through the relay to the light. Then the light will be on until you turn the key to the "on" position.
__________________
Daily Driver: 1982 Toyota Pickup Base 2WD 22R, TRD Cam,5-sp Manual, Toyota Truck Nation High Miler- 300k+
MPG: 25/32
Off-roader: 1990 Honda H3011SA Riding Lawnmower, 11hp OHV engine, Carlisle SNOW-HOG Tires
MPG: 1 Day of "Wheeling" per gallon
Come to the 2nd Annual Oregon Yotatech Meetup!
June 26-29, 2009: Browns Camp OHV Park
http://www.yotatech.com/f5/oregon-yo.../#post50902592
rowdy235 is offline
Old 05-11-2008, 01:36 PM   #3 (permalink)
Yopar's Avatar
Cool thanks, I'll try that out.
__________________
Yopar is offline
Old 05-11-2008, 07:45 PM   #4 (permalink)
Yopar's Avatar
Looks like I can just use a standard Bosch SPDT relay, and use pin 87a for the normally closed circuit.
http://www.coolcatcorp.com/faqs/relays.html
__________________
Yopar is offline
Old 05-11-2008, 10:16 PM   #5 (permalink)
Noltz's Avatar
^^ that's exactly what I was about to post. You can do that with no trouble.
Curious: Why the constant on? Alarm LED? Interior fan?
__________________
•-Noltz-•
'95 4Runner SR5, mostly Stock, w/OBA & AirLifts. His.
'97 4Runner Limited, Stock w/E-Locker & 285s. Hers.
'91 4Runner, 3" BL, 35's & 8000# Winch.
SOLD
Noltz is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
I need to retard ign timing? Proper way? MulletMan 86-95 Trucks & 4Runners 4 04-03-2008 06:11 PM
Replacement door/ign keys InternetRoadkill 86-95 Trucks & 4Runners 2 12-07-2007 04:07 PM
IGN fuse keeps blowing Lon_Godhelm General Electrical & Lighting Related Topics 0 11-23-2007 10:46 PM
Replacement Ign/door locks 1eye General Vehicle Related Topics (Non Year Related) 4 11-16-2007 12:48 PM
have some ign. timing issues. . . . MightyToy 86-95 Trucks & 4Runners 3 02-28-2006 10:23 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
