| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
No power/memory without key in ignition
#2 (permalink) |
It sounds like something in the sterio system has gone bad or is going bad and causing strange things to happen, especialy if it just started blowing fuses for no reason at all.
__________________
86 Toyota 4Runner Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper. |
#3 (permalink) |
That could be, but several other electrical devices are acting up at the same time. The 12v power outlets remain alive and the "P" light indicating the truck is in Park also remains lit up. There must be a common relay or something that these electrical items flow through that allows or removes power based on ignition?
#4 (permalink) |
Just curious is ur dome light still working?
Check all ur fuses sounds like a blown fuse.Ur radio circuit works off the dome light fuse.We get alot of customers come in with similar problems most dont check the easy stuff first like fuses.
| Tags |
| ignition, key, power |
