New Tach problems - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-21-2008, 11:17 PM   #1 (permalink)
j's85's Avatar
New Tach problems
I have an 85 pickup with a 22r in it and I just bought a Sunpro tach today. I have everything wired up exept for the green wire that is supposed to connect to the coil. I can't figure out were i need to connect it. Any thoughts? Thanks
j's85 is offline
Old 02-22-2008, 05:26 AM   #2 (permalink)
91 4Runner's Avatar
http://www.yotatech.com/f116/tach-in...-22r-e-127036/
A bit farther doen this thread should help a bit.
__________________
Mostly Stock 90 4Runner SR5 V6 Auto w/ 33" Durango MT's (bent lower valance removed), bush bar w/ 55w Baja Offroad Lights, Custom fit 1st. gen rollbar (used to mount Hi-Lift and fire extinguisher), extended diff breathers, (Comming soon rear spool and 2" body lift..)
My very slow buildup on Sontt.com - currently building.
http://www.sontt.com/forum/viewtopic...&t=109&start=0
91 4Runner is offline
Old 02-22-2008, 10:12 AM   #3 (permalink)
deserttoy84's Avatar
Send a message via AIM to deserttoy84
you connect the green wire to the negative of the coil... below is two pics of the two different coils on 22r(e) and where you need to connect it too
__________________
1984 toyota sr5 4x4
22r w/ weber 32/36
Pro comp 4" front springs & 3" rear downey spring
Home made On-board air system
V6 4.88 lock rites F & R
Bilstein 7100 reservoir shocks
deserttoy84 is offline
Old 02-23-2008, 07:37 AM   #4 (permalink)
j's85's Avatar
Thank you very much deserttoy. I hooked it up today but it still isnt working so im guessing my tach is bad.
j's85 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
85 tach j's85 84-85 Trucks & 4Runners 8 02-23-2008 07:39 AM
New Tach, New Problems 81redbluffyota Pre 84 Trucks 1 01-04-2008 05:42 PM
SR5 tach cluster upgrade question...no tach vwfastg60 86-95 Trucks & 4Runners 2 11-06-2007 12:56 AM
tach problems maxxjq 95.5-2004 Tacomas & 96-2002 4Runners 2 09-04-2006 06:25 PM
Tach Help!!! motorhead99 95.5-2004 Tacomas & 96-2002 4Runners 2 07-30-2004 12:16 AM
2009 InternetBrands, Inc.
