YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-14-2007, 01:30 PM   #1 (permalink)
Lights on HELP.. trans light, charging light, and brake light
Hey there everyone, i have a problem. my toyota decided to take a crap on its new owner, and i had to refund his money, "won't happen again" anyway here is what is going on, it died on him once and he boosted it off and before that the automatic tranny heat light is on, the chargin light is on, the brake light is on, BUT everything works the back window, the lights the blinkers and even the AC and it is running fine other than these lights, also i pulled the positive battery cable and it stayed running without the lights on, with lights on it died, this has always pointed toward a bad alt if it ran with no battery cable and no lights on to pull it down. Let me know if u have seen this problem before. Thanks.. also checked the connection, and checked the fuse the engine fuse all was well..
krash2k77 is offline
Sponsored Links
To remove this ad, register today!
Old 04-14-2007, 02:47 PM   #2 (permalink)
Check the output of the alternator, it sounds as though it's not charging. With the engine running put a volt meter across the battery terminals, it should read 13.5 to 14 volts. This isn't a load test but gives you a general idea.
1994runner is offline
Old 04-14-2007, 04:19 PM   #3 (permalink)
ok here is what i got.. WIERD ITEM. Usally when a belt if loose it makes a noise. well i don't know if it is fixed but i noticed that when i revved the engine after driving 30 miles i went to pass someone and wow the lights went off. Then i slowed back down and the lights came on, so i test the battery before i left walmart in cleveland,tn and it was barely reading 12 it was like 11 something with the lights all on, and the ac on. now u tell me what american car can run with hardly any electric lol. anyway i got home and checked it, it was 12.3 i think. So I revved it and after a sec of revin the out put went to over 13.8 and then it settles down and idles and set at 13.33 weird. The lights went off.. So then after that it tests 13.33 and with all the lights on it is like 12.8 i know this isn't the best but not the worst either. u tell me i tightend the belt but before i did i revved it up and that is when the lights went off and it went to charging? could this be a loose belt? I thought? HUMM? Well i will tighten it so i did and 13.33 at idle.. Could this be a ECu problem? i have never had this happen and it just did today..
Old 04-16-2007, 06:20 AM   #4 (permalink)
firemedic's Avatar
Sounds like alternator may be on its way out...
__________________
Ben Silva
96 Lexus LX450, 125k, front/rear OEM diff locks, CDL switch, Pin 7 mod, power points, wired 850w inverter, jdm "oh crap" bar, OME heavy (850/863) lift, 285/75/16 Cooper STT, spare tire lift mod
98 Lexus LX470, 135k, Britax car seat ;)
TLCA member #14300
Camas, WA USA
firemedic is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Question about my dad's 94 toy's battery light and brake light staying on?? whitetaco02 86-95 Trucks & 4Runners 20 10-25-2006 06:16 PM
94 22re Brake Light & Batt Light + Overheating mmunoa 86-95 Trucks & 4Runners 3 07-18-2006 01:58 AM
A/T light, brake light, & battery light ON!! mdhunter 86-95 Trucks & 4Runners 3 03-13-2006 05:21 AM
Dash Brake light coming on under braking along with batt light DravisAR Maintenance & Repair Archives 2 07-25-2005 07:22 AM
84 pickup 22re battery light and brake light on eroc1313 95.5-2004 Tacomas & 96-2002 4Runners 3 04-30-2003 06:52 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
