Ignition switch wire questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-28-2009, 06:31 PM   #1 (permalink)
Hey, so I replaced the ignition switch on my '89 4runner (truck starts now, yay!) but as I was pulling out the old switch and wiring harness I noticed that a few wires on the harness had been spliced. The wire that had been spliced was a Black w/ White stripe. What does this wire do??? I don't know if I want to splice in my B / W wire like the previous owner did or just remove the wiring. Everything on the truck seems to work. I tried to follow the solid back wires that the BW had been spliced into but it goes into the main harness and I couldn't trace it.
Jadri is offline
Old 10-03-2009, 08:01 PM   #2 (permalink)
myyota's Avatar
Put it back to stock if you can and everything should work.
__________________
86 Toyota 4Runner
Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper.
myyota is offline
Old 10-04-2009, 03:13 PM   #3 (permalink)
turns out it was some sort of ground for my (aftermarket) horn. The horn wouldn't work without those wires spliced in whatever, it works now
Jadri is offline
Tags
92, 98, igniton, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
