Ignition lock question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-22-2009, 12:21 PM   #1 (permalink)
taras's Avatar
Hello fellow users.
I didn't know where to post this best but I want to ask about a problem with the ignition barrel. The key turns, engine starts, I turn the key to shut down the engine, the key turns to ACC but won't go into the off position. It can only be taken out by disconnecting the battery, as I've noticed. I heard it may be the wear of ignition barrel but I suspect some electrical circuit breaker failure. Can anyone shed some light on this, please? I'd appreciate it.
Thank you.
taras is offline
Old 08-22-2009, 12:41 PM   #2 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Well the computer section certainly isn't the correct section....what kind of vehicle are we working on?
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Old 08-22-2009, 08:52 PM   #3 (permalink)
taras's Avatar
Yes, sorry, forgot to tell the brand: this is a 1991 Toyota 4Runner.
taras is offline
Old 08-22-2009, 09:03 PM   #4 (permalink)
Tragic Drive's Avatar
Odd Problem. Have you tried to use cylinder lock graphite or other lubricant ?
__________________
,Thomas
Supercharged 3.4 in a ARB Locked 95 Runner
Tragic Drive is offline
Old 08-22-2009, 10:08 PM   #5 (permalink)
taras's Avatar
Actually, I haven't. This is its original ignition barrel, so it might be no good. I wonder how much it'd cost to replace it and who does it. Or it might be some electrical problem - not mechanical, definitely. =)
taras is offline
Old 08-23-2009, 09:44 AM   #6 (permalink)
use the graphite as suggested and use some patience--just keep working the key "gently" and i belive you'll have it handled--you may have to put the key in and out while using the graphite, once you get it to that stage, in order to relieve the unit from accessory to off--also if it's an automatic make sure it's fully in park--
sotb3 is offline
Old 08-23-2009, 10:25 AM   #7 (permalink)
CyMoN's Avatar
sounds like something is broken either on the ignition switch or in the tumbler
click on the second link and look in the steering section they have a break down on the steering column and the ignition switch.
http://www.yotatech.com/f123/links-f...-url-s-102344/
__________________
my rigs
89 4runner
1989 4runner v6 5 speed everything factory +4susplift running bfg 31s and a aux gas tank and more aux lights than needed
86 pickup
1986 stock pickup 22r 31.10 BFG ATs flatbed
a sad day for the 4runner
"One moment of patience may ward off great disaster. One moment of impatience may ruin a whole life."
CyMoN is offline
Old 08-23-2009, 11:45 PM   #8 (permalink)
taras's Avatar
Thank you, gentlemen! I'll be looking into this. Lacking time a bit, so it'll be a while. =) Thanks for the help again!
taras is offline
Tags
2003, 4runner, cost, cylinder, graphite, ignition, installing, key, lexus, lock, put, replace, switch, toyota, wa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
