idiot abs fuse thread, what part do i pull? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-24-2009, 01:02 PM   #1 (permalink)
theizzardking's Avatar
does the whole yellow housing come out? or do i open the little plastic door and pull the fuse inside of it out? thanks for helping with this bout of stupidity!
just wanted to be sure before i started pulling on things to hard!
__________________
1999 4runner limited, stock as of now.
'71 vwbus
http://www.thesamba.com/vw/forum/vie...light=wanderer
and a good laugh
http://www.amazon.com/Mountain-Mens-...owViewpoints=1
Quote:
Originally Posted by Texas Jim View Post
Just like Christ, you are crusified by the others who think they are with out sin!! TJ
I too will be baned for speaking of such things.
theizzardking is offline
Old 08-24-2009, 03:45 PM   #2 (permalink)
maybe a bit of a back story will spur someone into action!
doing some work on my brakes as they tend to shudder when i'm coming to a stop, i have already replaced all pads calipers and rotors, still had the problem took the rotor's off and had them turned, replaced everything and still having the problem, pulled everything back off and wire brushed the hubs back to the surface , put it all back on, still having the same problem, now my runner sits at a shop getting the rotors turned on the hubs we will see what the issue is i'd like to be able to pull this foose (sic) so i can do a quick check to see if it's the abs system be for i end myself ;-)
the shudder gets worse with speed but is noticeable through all speed ranges.
any thoughts?
(the brakes have been bled so no air in the system)
thanks guys!
__________________
'71 vwbus
and a good laugh
Tags
abs, fuse, pulling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
