I got some 8 gauge sound system wire - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-14-2009, 01:32 AM   #1 (permalink)
Would it be good for running from the alternator? I am planning on installing my Hella 550s, along with the Hella floods, so I want to pre-wire it for a higher output alternator. The wire I have is Kicker Hyper flex Power Cable (it has a bunch of tiny strands to make it super flexible). I got the cable for free from a friend, and want to put it to good use. I have 2 5ft pieces of it (one blue casing and one gray casing)
broyota is offline
Old 09-14-2009, 02:35 AM   #2 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
I wouldn't source power for anything from the alternator output- it should all come from the battery. Might not make sense but that's how it should be. You want a central point for wiring accessories and such and the battery is a logical point to connect to.
Afterwards, upgrade the wiring from the alternator to the battery as required.
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 09-14-2009, 05:25 AM   #3 (permalink)
I am not running the lights from the alternator lead, but from the battery. I am planning a 2 battery system as I will be working at a ski resort this winter, so I need extra CCA's when it is 0 degrees F outside. The Hella 550s came with a relay to run from the battery, so I will just copy how I had them installed on my Suzuki Sidekick. I am just wondering if 8 gauge wiring is enough to handle the loads? If it isn't, I will source better wiring (I am trying to plan in advance for making it hold up to harsh climates, and demanding conditions). I am also planning on getting a higher output alternator.
broyota is offline
Old 09-14-2009, 06:11 AM   #4 (permalink)
James Dean's Avatar
If your are installing an 80 amp plus alternator I would run 6 gauge, even on a short run 8 may get warm on a heavy draw.
If you are asking about the wire to the lights, that all depends on how many lights and how long your run is. However 8 gauge should be enough to run 2-3 lights.
If you are asking if it enough to run between your 2 batteries then NO. Even a short run between two batteries should be at least 4 gauge, preferrably heavier. My dual battery is in the back of my 4Runner (16' run) and I used 2oht.
__________________
Custom painter and Toyota Stripe and decal supplier.
http://jamesdeancreations.com
Custom Safari and Crawlin accessories.
http://www.jamesdeancreations.com/4runner_project.htm
James Dean is offline
Old 09-14-2009, 07:00 PM   #5 (permalink)
myyota's Avatar
Im in the process of gathering parts for my MR2 100 amp alternator swap, and im upgrading the wire from the alternator from the stock 8 gauge to a much heavier 4 gauge, and im running the wire directly from the alternator to the battery and then from the battery to the fuse box, and then im removing the unused factory wiring. The 8 gauge wire you have probably won`t be heavy enough, thats just my opinion, and it may work just fine, but if you plan on doing an alternator upgrade the 8 gauge definatly won`t be heavy enough, i would recoment at least 4 gauge wire.
__________________
86 Toyota 4Runner
Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper.
myyota is offline
Tags
alternator, amps, battery, cable, dual, gauge, gud, power, running, short, sound, soundsystem, system, upgrade, wire, yotatecg
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
