| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
help wiring a tach
#2 (permalink) |
the red and white will go to you dash lights..it is what gives it light..look online for some instructions and it will tell you where you need to put em..
the green wire is the RPM signal..you could just tap into the tach plug that is on your coil..if its wired for a tach..
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE 1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous "Its still a toyota man.. Dont deprive it of its capabilities.." "If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009 |
#3 (permalink) |
i just installed a sunpro super tach in my 94 single cab std. bed. the black ground i connected to an already established ground behind the drivers side kick panel, the red power also went behind the kick panel but into the fuse block this time. the green signal wire i spliced into the black coil wire. and the white light wire i also plugged into the fuse block as a constant on because i had issues with connecting mine to the dimmer switch then i screwed into the steering column shroud and hung the tach on top and to the left a little bit
__________________
94 truck .slow, 5sp. 22re, 4in. superlift 33.12.5'' bfg mt's, pro comp streetlock 15x10's sony head unit 2 4x6's in the dash 1 10'' sub 1000w amp Last edited by 94YOTAG; 09-05-2009 at 10:12 PM. |
#4 (permalink) |
exactly..
i have the white wire going to the dash light fuse in the fuse block..and the red wire is going to the ignition fuse and the black is grounded (of course) and the green is tapped into my tach wire..
__________________
| Tags |
| 22r, 4x4, 93, black, green, hook, red, sr5, tach, tachometer, toyota, white, wire, wires, wiring |
