YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-01-2007, 06:51 PM   #1 (permalink)
Help!! Fuse melting
I have a 1988 22RE pickup. My problem is that the hot wire that is coming into the fuse box for the EFI relay is getting hot and melting the fuse. I have run a direct wire from the battery into the fuse box but it still heats the fuse and the relay up. So I think it might be the mass air flow sensor, but I'm not sure. Anybody got any ideas?
jonboy99 is offline
Sponsored Links
To remove this ad, register today!
Old 08-23-2008, 02:21 AM   #2 (permalink)
Check Main Relay And Connecting Relay.......could Be Bad
4wheeler808 is offline
Old 08-23-2008, 09:07 AM   #3 (permalink)
4Crawler's Avatar
Find out what is pulling too much current on that circuit. Common cause is an O2 sensor wire that has fallen against the hot exhaust, melting the insulation and causing a short.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-04-2008, 04:01 PM   #4 (permalink)
894x4pickup's Avatar
Take the black top off the AFM and make sure all the little metal contacts are facing up and not touching any other of the contacts...thats what happened to me...
__________________
1989 Gray Std. Cab 5 speed 4x4
RV Cam
Stock Lift, 31"x11.5" TSL Super Swampers in back,
31"x10.5" Bridgestone Dueler M/T' in front. Aisin Hubs
894x4pickup is offline
Old 10-04-2008, 06:20 AM   #5 (permalink)
Hi all,
I went to wash my truck yesterday and rinsed the underbody near the motor and the check engine light began flashing. Drove for 7 miles, gassed up and proceeded, when the truck died. Its turning over but no fuel from fuel pump to filter. Replaced the fuel pump, but still no start. Found a bad EFI fuse (located on right in underhood fuse box) to replaced, tried again, but fuse blew again. Any advice would help. Thanks. DJ
dj86515 is offline
Old 10-04-2008, 06:31 AM   #6 (permalink)
4Crawler's Avatar
Likely a wire to the O2 sensor has shorted out either with the water or by touching the hot exhaust and melting the insulation. Check the stored code:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-04-2008, 11:19 AM   #7 (permalink)
Thanks for reply 4Crawler,
Slight progress. The vehicle started, drove it for a couple miles but the fuse burnt out again.
dj86515 is offline
Old 10-05-2008, 06:02 PM   #8 (permalink)
Hi all,
With the help here, I discovered small cracks near the base of the O2 sensor plug wires at the exhaust manifold. Elec taped them and no more blown fuse, however, the CEL flashes every now and then. Wondering if I gotta get a new O2 sensor now. The DD truck runs though and thanks, esp to 4Crawler. DJ
dj86515 is offline
Old 11-05-2008, 06:05 PM   #9 (permalink)
Hello again,
I was ok there for a few weeks, until this morning after 30 miles of travel on melted snow slush puddles (wet). I pulled over on the side of the road to let my dogg off. I went to start the truck, nothing...took out 3 fuses instantly. Girlfriend came in the 4Runner, towed truck for 10 miles and let it sit at a store for about 3 hours. Came back to the truck to tow it again but she said maybe it dried by now. I throw a new fuse in there and fires up andI returned. Lost confidence now that the girlfriend knows wuts up with the truck. Any suggestions would help. Thanks again. DJ
dj86515 is offline
Old 11-05-2008, 06:15 PM   #10 (permalink)
4Crawler's Avatar
Would help to tell us what fuses are blowing out, or is it one fuse blowing out 3 times in a row? Find out what items are on the circuit of the fuse(s) that are going out and try systematically eliminate things on that circuit until the fuse no longer blows out.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 11-05-2008, 06:45 PM   #11 (permalink)
That would help, sorry.
It is the EFI fuse (15) that blows out and did blow out after 3 replacements in a row this morning. Thanks. DJ
dj86515 is offline
Old 11-05-2008, 06:57 PM   #12 (permalink)
Send a message via AIM to akaphilly
i'd check your pervious fix on the 02 sensoe wire.. really clean it up and seal it nicely.
akaphilly is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Help!! Fuse melting jonboy99 Newbie Tech Section 1 07-01-2007 07:22 PM
Help!! Fuse melting jonboy99 86-95 Trucks & 4Runners 1 07-01-2007 07:19 PM
Melting Headlights? msw0085 95.5-2004 Tacomas & 96-2002 4Runners 9 02-18-2005 03:24 PM
Which Fuse Is The EFI Fuse? DiSperlonga 95.5-2004 Tacomas & 96-2002 4Runners 4 11-13-2004 08:52 PM
Melting the Cat in a 3rd gen 4runner RawRunner 95.5-2004 Tacomas & 96-2002 4Runners 1 03-30-2003 08:17 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
