| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
hella 500's...any wattage?
#2 (permalink) |
well, I did, right now I'm running the 100w each bulbs.... so far no problems, it will draw 15.3 amps instead of 8.5 amps at 13V ..
Amps = watts/voltage, so calculate with whatever V you want I think they normally come with a 15amp fuse? not sure, i've allready used larger wiring and a bigger fuse, but can't guarantee any situation go here http://www.powerstream.com/Wire_Size.htm for wire size and load guide... I always factor in a little extra for safety and additions
__________________
Andrew J W = WJwerdnA '99 4Runner SR5 - Pioneer MP3/IPod w/Infinity all around - lifted 2.5-3in susp. - 33's to fill the gap - sliders - ISR & Deckplate, yada yada - Satoshi - AIM:wjwerdna YotaTech Profile Custom Bumper Link for sale: ??? Nothing? |
#3 (permalink) |
oh, to answer your question, any wattage, in theory no, I don't remember if I found anyone that actually had a problem with the 100's and melting housing, but I figured, what they hey, I'll give it a try... If you do, make sure your relay is rated for 20A or more, or it probably won't last... also I don't remember if I had to modify the bulb housing with pliers (easy) or if it was just because I missed something obvious, but either way they go in relatively easy and are a little brighter
__________________
#4 (permalink) |
I put 100w bulbs in my 500 fogs. See m to work fine, the housings are all glass and metal so should hold up to the additional heat. I did put in a new 30 amp relay to replace the old Hella relay, it had fried with the new bulbs:
- http://www.4crawler.com/4x4/CheapTri...shtml#HOrelays
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#5 (permalink) | |
Quote:
I did it! It works without problems. If you are winching or sitting still, I would not sit there with the 500's/100watt bulbs on for too long. They do need some air flow to keep from overheating and causing damage. Other than that precaution, do it! You'll be glad you did!
__________________
'91 4WD 4Runner SR-5 3.0 V6 EFI K&N Gen 1 FIPK (modified with oiled foam pre-filter & pre-charger) Good flow, less dirt 32" Nitto Terra Grapplers on 16" '01 Sequoia Wheels axle code G254 Auto trans A340H Eclipse NAV/Audio, Alpine amps, JL Sub 2001 4WD Sequoia Limited 4.7L iForce V8 2.5" DayStar lift 33" BFG MT's on Weld Racing 16x8" Velocity 6 wheels Manik Stainless Brush Guard and tail light guards KC HiLites H.I.D. Aux lighting up front |
#6 (permalink) |
is there anything in between 50 and 100 watts? Maybe a 75 or 80 watt bulbs?
#7 (permalink) | |
http://www.rallylights.com/hella/H3.asp has 85w YellowStar H3 bulbs, seems they should work, but obviously yellow
Quote:
__________________
#8 (permalink) |
I see a few from tooling around the web...
Sylvania Silverstars makes a 65w H3 Sylvania Standard makes a 70w H3 (Part #64156) Doing a simple eBay search I can find basically any wattage H3 I can think of. 80w 5000k H3 on eBay Anyway, I just don't want to have to buy another burn the lights/wires/covers/etc... and realize I could have gotten some 5" 100w PIAA's for the cost I have put into 2 Hella 500's. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Hella 500's | 95RunnerSR5 | 86-95 Trucks & 4Runners | 20 | 08-05-2006 03:20 PM |
| Hella 500's are on | 4x4Fink | 95.5-2004 Tacomas & 96-2002 4Runners | 24 | 03-29-2004 07:27 PM |
| Hella 500's | CMD93 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-18-2004 05:00 PM |
| Hella 500's Help! | mochoajr | 95.5-2004 Tacomas & 96-2002 4Runners | 16 | 01-09-2004 05:04 PM |
| Amber Hella 500's | AFRunner | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 11-08-2003 03:28 PM |
