General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Headlight issue
Old 10-03-2016, 07:00 AM
SamMorningstar's Avatar
Headlight issue
I recently installed new head lamps in my 91 pickup. The old ones worked fine but I wasn't happy with the brightness. Now the driver side low beam doesn't work with any of the four lamps i plug in there (2 old 2 new). My tester light is showing all 3 contacts in that connecter to be hot. All wires and connectors seem to be in good shape. Could this be a fuse or relay problem?
Old 10-03-2016, 12:40 PM
Fossilized
Staff
dropzone's Avatar
if all 3 are showing hot, you have issues, one should be the ground and therefore 0 v. What is it that you did when you weren't happy with the brighness (besides install new lamps)? Any wiring tweaks?
Old 10-03-2016, 12:53 PM
Nothing else just new lamps. I don't know much about wiring so I mess with it as little as possible.
Edit I should add that I'm only reading all 3 hot when the lamp is plugged in
QUOTE=dropzone;52337300]if all 3 are showing hot, you have issues, one should be the ground and therefore 0 v. What is it that you did when you weren't happy with the brighness (besides install new lamps)? Any wiring tweaks?[/QUOTE]
Old 10-03-2016, 01:44 PM
wyoming9's Avatar
It is possible you broke a wire at the head light plug
Then maybe removing the old bulb moved corrosion around on the plug
Have you checked that the lights even work ??Every thing is fine on the right side??
The single pin is the voltage from the head light fuse
Old 10-03-2016, 02:54 PM
Removed each contact from the plastic housing and cleaned them. Everything intact. Tried switching the bulbs they both work fine on the right side.
Old 10-03-2016, 11:50 PM
wyoming9's Avatar
It has to be a problem right in that area since things worked fine before you unplugged things
Poppie51
08-20-2016 05:36 PM
lalojamesliz
08-11-2016 06:56 AM
lalojamesliz
08-08-2016 10:48 AM
TheOriginal
08-08-2016 06:01 AM
cbr600rx7
07-29-2016 09:36 AM
Quick Reply: Headlight issue
