YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-22-2008, 04:41 PM   #1 (permalink)
Hazards work but not turn signals
I just bought a 92 pickup a few weeks ago. In the process of doing some rewiring for the front right turn signal bulb, I managed to pull off a double whammy. I reversed the wires and put in the wrong bulb: I used single filament rather than a dual filament. When I went to test the signal, the interior indicator light came on for a split second (I think) then died. I fixed the screw ups and now my hazards work fine but my turn signals don't work at all. I checked all the fuses in the box in the engine compartment and they are all good. I also tried a new flasher module but that didn't change anything. I know they were working before I started farting around. Does anyone have any suggestions? Thanks.
alphaniner is offline
Sponsored Links
To remove this ad, register today!
Old 07-01-2008, 05:51 PM   #2 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
So, when you turn on your 4 ways all the signals work fine? Outside and in?
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Old 07-02-2008, 07:26 AM   #3 (permalink)
eric-the-red's Avatar
Check the fuses inside, under the dash on the left hand side. #9, which is the bottom right, is for the turn signals.
eric-the-red is offline
Old 07-06-2008, 03:17 PM   #4 (permalink)
rowdy235's Avatar
also the hazards and the blinkers use different flashers, you could have blown your blinker flasher. I'm not exactly sure where it is.
__________________
Daily Driver: 1982 Toyota Pickup Base 2WD 22R, TRD Cam,5-sp Manual, Toyota Truck Nation High Miler- 300k+
MPG: 25/32
Off-roader: 1990 Honda H3011SA Riding Lawnmower, 11hp OHV engine, Carlisle SNOW-HOG Tires
MPG: 1 Day of "Wheeling" per gallon
Come to the 2nd Annual Oregon Yotatech Meetup!
June 26-29, 2009: Browns Camp OHV Park
http://www.yotatech.com/f5/oregon-yo.../#post50902592
rowdy235 is offline
Old 07-06-2008, 04:41 PM   #5 (permalink)
86tuning's Avatar
^^ negative ghostrider.
The hazard and blinker flasher is the same unit.
Usually, if the hazards work, you have a signal switch problem of some sort.
Cheers.
__________________
- Brian
86tuning is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Turn signals wont work js9924 86-95 Trucks & 4Runners 22 05-08-2008 10:49 AM
Turn signal, hazards not working question. Shoxg711 General Electrical & Lighting Related Topics 19 02-26-2008 07:34 AM
Hazards will light up - But Blinkers won't work! Lysmachia General Electrical & Lighting Related Topics 3 06-07-2007 07:18 PM
new head unit, now horn, clock, and hazards don't work alanbobalan Vehicle Audio & Home Entertainment 11 05-29-2005 06:15 PM
signal and hazards dont work. kevin444 95.5-2004 Tacomas & 96-2002 4Runners 27 12-04-2004 02:52 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
