| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Front turn signals broken, all fuses fine.
#2 (permalink) |
Bump...
I would really appreciate some advice. |
#4 (permalink) |
The rear hazards work fine, but the front hazards do not work.
#5 (permalink) |
Would help to know what sort of vehicle this question is about.
Any voltage at the front turn signal sockets? Do you have a good ground there?
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#6 (permalink) |
Its a 1993 4Runner.
At the moment I'm in college and don't have any tool to check voltage. I did run a power cable through the firewall on the drivers side for an amp, I'm wondering if thats where the wires are...? |
#7 (permalink) |
You'll find a fastory manual for 1990-1995 4Runners here, it should have a wiring diagram. And if you're going to be doing any electical testing it's a good idea to buy a digital voltmeter, you can get cheap ones for less than $20.
http://www.ncttora.com/fsm/index.html
__________________
2001 4Runner 4.30 ratio 1999 e-locked rear axle and front diff; OME881/N91S front; OME891/N86 rear; Tundra brake swap; 1" 4Crawler body lift; 63" 4Crawler SliderZ; TJM T-15 with Warn M8000 winch and Amsteel blue synthetic line; 265/75R16 Nitto TGs or 255/85R16 Truxs MTs; Cobra 75 WX ST cb; Alinco DR635 VHF/UHF ham radio; ham call sign license plates - VE7 EGC |
