| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Front A.D.D diff electrical plug connection??
__________________
1988 Toyota 4x4 V6 5spd long box **RESTORED** 1984 Toyota 4x4 22R 5spd Ext cab 3" B.L on 36"x10.5 1993 Toyota 4 Runner, 22re 5spd, Pwr loks,win,Air,Crz 1991 Toyota 2wd 22RE 5spd short box 1994 Toyota 4runner, V6 Auto *SOLD* 1985 Toyota 4x4 22RE 5spd long box*Parted out* 1980 Toyota 4x4 22R 5spd short box *SOLD* 1985 Toyota 2wd 22RE 5speed 1 Ton *SOLD* 1987 Toyota 4x4 22RE 5speed 4Runner *SOLD* Last edited by Toyotoy; 09-25-2009 at 06:54 PM. |
#2 (permalink) |
I don't know if you have solved the problem yet, but I'd take your question over to the 86-95.5 forum and ask again. I'm sure someone with ADD will answer your question. There are a bunch of really talented folks over there. I don't have ADD so I can't help you.
__________________
'89 V6, 5 spd truck and '07 FJ Cruiser |
#3 (permalink) |
That wire isn't for the front diff. The connector for the diff is already plugged in. And t's not for the actuator, that is totally vacuum operated. The wire just plugs into a switch that turns on the 4WD light when the diff is engaged. I would have a look above the diff for a matching plug for that wire.
It's been 4 years since I owned a 2nd gen so I'm not sure what else is around there.
__________________
2001 4Runner 4.30 ratio 1999 e-locked rear axle and front diff; OME881/N91S front; OME891/N86 rear; Tundra brake swap; 1" 4Crawler body lift; 63" 4Crawler SliderZ; TJM T-15 with Warn M8000 winch and Amsteel blue synthetic line; 265/75R16 Nitto TGs or 255/85R16 Truxs MTs; Cobra 75 WX ST cb; Alinco DR635 VHF/UHF ham radio; ham call sign license plates - VE7 EGC |
#4 (permalink) |
Thanks for that, that helps a bunch, still havent found any empty wire that is for that plug...i will keep looking, thanks
__________________
1988 Toyota 4x4 V6 5spd long box **RESTORED** 1984 Toyota 4x4 22R 5spd Ext cab 3" B.L on 36"x10.5 1993 Toyota 4 Runner, 22re 5spd, Pwr loks,win,Air,Crz 1991 Toyota 2wd 22RE 5spd short box 1994 Toyota 4runner, V6 Auto *SOLD* 1985 Toyota 4x4 22RE 5spd long box*Parted out* 1980 Toyota 4x4 22R 5spd short box *SOLD* 1985 Toyota 2wd 22RE 5speed 1 Ton *SOLD* 1987 Toyota 4x4 22RE 5speed 4Runner *SOLD* |
#5 (permalink) |
Look near the oil filter
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 | CompuStar Auto-start| two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler '88 4runner|22re|5spd|206K miles|Sold '93 single cab|22re|5spd|150K miles|Sold| Pro IFS Last edited by toyota4x4907; 09-27-2009 at 05:25 PM. |
