Flashing Overdrive light - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-09-2009, 02:09 PM   #1 (permalink)
Yesterday I tore out the entire interior on my (auto) 93 4runner and installed a new stereo, after putting everything back together and starting the truck up I decided to go for a drive and enjoy the new system, but the truck had trouble going as I had to rev it up to 3k rpm before she would move.
After a few minutes of driving I noticed that the OD light was blinking. So now I am thinking that I did something during the stereo install, I checked the computer, speed sensor but everything looks plugged in and connected.
Has anyone else had issues after doing a stereo install? Would a bad ground or disconnected wire cause the transmission to go limp?
I installed 2 amp, new deck, subwoofer, speaker pods with components, would a stereo that demands more draw from the electrical system cause it to shoot out codes??
The only stupid thing that I did was screw in a small shallow screw ( into the main electrical harness holder that runs down the passenger side (engine bay) to hold the stereo fuse, I have since removed the screw but OD still flashing.
Any input would be great thx! it is very possible I am assuming that its just a coincidence with the install and could very well be something else.
Yotalove is offline
Old 11-09-2009, 04:21 PM   #2 (permalink)
Well its not the wiring harness, I pulled the plastic sheathing off and all the wires are good no damage whatsoever.
Yotalove is offline
Old 11-09-2009, 05:19 PM   #3 (permalink)
eric-the-red's Avatar
A flashing OD light means the computer has a stored trouble code. It could be from something you did, or it could just be coincidence. Check the codes and go from there.
Instructions are in here
http://www.ncttora.com/fsm/1990-1995...2/troubles.pdf
__________________
2001 4Runner
4.30 ratio 1999 e-locked rear axle and front diff;
OME881/N91S front; OME891/N86 rear;
Tundra brake swap;
1" 4Crawler body lift;
63" 4Crawler SliderZ;
TJM T-15 with Warn M8000 winch and Amsteel blue synthetic line;
265/75R16 Nitto TGs or 255/85R16 Truxs MTs;
Cobra 75 WX ST cb;
Alinco DR635 VHF/UHF ham radio;
ham call sign license plates - VE7 EGC
eric-the-red is offline
Old 11-09-2009, 09:19 PM   #4 (permalink)
OK so I did the diagnostic and its giving me 6 flashes puase 2 flashes which is code 62 which means there is an issue with #1 solenoid. I suppose I will just have to bring her to the garage. Ty for the help Eric
Yotalove is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
