YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-07-2008, 08:01 PM   #1 (permalink)
ETRNL's Avatar
electric guru needed. 28v system
i am looking for someone to help me build/convert a way to run 2 sets of lights with the following specs out of my 4runner...
28vdc
5amp
250w
should be simple, i hope..
anyhow plese let me know if you can help.
THNKS ETRNL
__________________
2001 4Runner LTD, ISR/deckplate/ECT mod, 6K HIDs, 12g headlight wire harness, Satoshi, Hood Emblem, fog light mod, constant power mod, NO DRLs, Remote start with ~1 mile range.
my favorite video
ETRNL is offline
Sponsored Links
To remove this ad, register today!
Old 07-07-2008, 09:31 PM   #2 (permalink)
4Crawler's Avatar
Search for "DC to DC converter":
http://www.google.com/search?q=dc+to...ient=firefox-a
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-07-2008, 09:59 PM   #3 (permalink)
ETRNL's Avatar
ok so i tried just using 2 batteries and that looks to be easier. now, how does one go about charging 2 batteries in series with the stock alternator?
__________________
my favorite video
ETRNL is offline
Old 07-07-2008, 10:15 PM   #4 (permalink)
4Crawler's Avatar
Hard to do directly. One option would be a series-parallel switch or relay so you could put the batteries in parallel to charge, then switch them to series mode to power the load. Depending on how long the load needs to run and how big the battery is (Amp-Hour rating), that may work. Or you might be able to rig up some sort of electrically floating battery charger for the 2nd battery (essentially a DC-DC converter). Or add a 28 volt alternator to the engine or make up a motor-generator unit (12V motor driving a 28V alternator) and use that.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Info needed on wiring fog & driving lights into OEM system runnerSR5 95.5-2004 Tacomas & 96-2002 4Runners 5 11-06-2006 03:59 PM
Electric cooling fan modification tips needed Graywoulf 95.5-2004 Tacomas & 96-2002 4Runners 13 12-27-2004 09:49 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
