EFI fuse keeps blowing?
I have the same problem. Just started in the last week or so. Was told by the dealer it could also be the EFI relay or circuit opening relay under dash. Mine blows fuse when I turn key to start. Thought it might be the fuel pump, but removed the circuit opening relay to test it, and problem is still there. Fuse went last week when wife was driving down the road. All relays seem to test ok. 95 x-cab 4x V6 auto. Any thoughts?
Make sure that your ground wire from the bat to the engine is first rate and check the ground wire for the efi circuits( located on the passenger side of the motor just below the aluminum air intake, about in the middle,a large wire bolted on). Good luck!
I'm having the Same problem. Did you ever fix the blowing of the fuse? Mine was in the shop for 1 week, they could not find it, maybe you can help. Thanks
Post on APPRORIATE FORUM (MODEL-year), get multi-meter, find Schematic and share here and we'll help you.
bryan34w
12
09-30-2015 02:50 PM
