DRLs - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-19-2009, 05:13 PM   #1 (permalink)
DRLs
Hi All,
Need to install daytime running lights to make my American purchased
truck Canada-worthy.
I talked to a Toyota tech and he said for a '99 4runner it's a simple relay matter.
Any help would be much appreciated!
JMorry is offline
Old 10-19-2009, 05:15 PM   #2 (permalink)
theAuthority's Avatar
I just searched "daytime running lights" and found this
http://www.yotatech.com/f131/daytime...ht-kit-189443/
Next time, try using it. Welcome to YotaTech btw.
__________________
Proud sponsor of the re-poster thread. Where there is Substance.
http://www.yotatech.com/f5/you-re-poster-193103/
theAuthority is offline
Old 10-19-2009, 05:25 PM   #3 (permalink)
thanks theAuthority, I came across this thread.
Maybe I'm missing it, but if there's a response to Daman's last post, that would help me out a lot.
JMorry is offline
Old 10-19-2009, 05:29 PM   #4 (permalink)
Just find an FSM for your vehicle, you haven't really told us what your vehicle is.
Find the headlight wire that is activated by your headlight switch and run it to an accessory power wire. If you've ever hooked up a stereo it's usually the red wire, while the yellow wire is constant power.
So ANYTIME you turn your key to accessory or to start it, your headlights will turn on.
__________________
Old 10-19-2009, 05:31 PM   #5 (permalink)
my bad - 1999 4runner.
JMorry is offline
Old 10-19-2009, 05:32 PM   #6 (permalink)
Found this, since I last posted ... took me 3 minutes google->tundra forums -> 4 runner forums -> yotatech haha
http://www.yotatech.com/f2/4th-gen-d...tml#post391085
__________________
Old 10-19-2009, 05:38 PM   #7 (permalink)
yup same one
JMorry is offline
Old 10-19-2009, 05:41 PM   #8 (permalink)
Ah crap I posted wrong one, forgot to copy and paste, give me 2 seconds
this is what I meant to post ..
__________________
Old 10-19-2009, 05:46 PM   #9 (permalink)
eric-the-red's Avatar
Quote:
Originally Posted by JMorry View Post
Hi All,
I have a used DRL relay from a 99 4Runner, it's yours if you want it. Don't know how easy it would be to install, maybe just plug it in or maybe some wiring would be needed. Or Canadian tire sells aftermarket kits for about $30
__________________
2001 4Runner
4.30 ratio 1999 e-locked rear axle and front diff;
OME881/N91S front; OME891/N86 rear;
Tundra brake swap;
1" 4Crawler body lift;
63" 4Crawler SliderZ;
TJM T-15 with Warn M8000 winch and Amsteel blue synthetic line;
265/75R16 Nitto TGs or 255/85R16 Truxs MTs;
Cobra 75 WX ST cb;
Alinco DR635 VHF/UHF ham radio;
ham call sign license plates - VE7 EGC
eric-the-red is offline
Old 10-19-2009, 05:51 PM   #10 (permalink)
if you believe it I've been searching for 2 hours - not as efficiently as you, apparently
thanks bud I'll give this a try
JMorry is offline
Old 10-20-2009, 06:31 PM   #11 (permalink)
Quote:
That would be great Eric. you ever come into Van?
JMorry is offline
Old 10-20-2009, 06:57 PM   #12 (permalink)
Godzilla's Avatar
You will learn alot about the setup of DRL's for 3rd gen 4Runners by searching "fog light mod" as many have to deal with the DRL to allow for the independent use of the fog lights.
It is weird that some (US) model 4Runner in 99 had a DRL setup where others did not.
If yours did not it may be easier to just go and pick up the kit from Cambodian Tire.
http://www.yotatech.com/f2/2-quick-h...runner-150139/
http://www.yotatech.com/f2/drl-help-17254/
http://www.top4runners.com/ja/fogmod.html
Godzilla is offline
Old 10-22-2009, 05:25 PM   #13 (permalink)
I'm giving you the part free, I wasn't really planning on including delivery as well
Actually my wife works in Vancouver so we could probably work some thing out for next week. What part of the city are you in.
__________________
2001 4Runner
Tundra brake swap;
Cobra 75 WX ST cb;
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
