YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-19-2008, 11:34 PM   #1 (permalink)
annoyingrob's Avatar
Dome light only works when passener door open?
I have weird problems with this truck's electrical system (86 pickup xtra cab). Most of the problems were solved by removing the REALLY POORLY INSTALLED alarm system, but there's still a slight issue with the dome light.
when I open the passenger door, the door light comes on, and the dome light comes on, like normal. When I open the driver's door, the key light, and the door light come on, but the dome light doesn't.
Does anybody have a wiring diagram, or has an idea of where to start looking?
annoyingrob is offline
Sponsored Links
To remove this ad, register today!
Old 08-24-2008, 09:29 AM   #2 (permalink)
mickeykreg's Avatar
Does the buzzer work when your driver door is open with key in the ignition? If not, then plug it back in. The annoying buzzer and dome light door pin are wired together. Check this buzzer kill link to get the best of both worlds.
http://siestaoff-road.web1000.com/buzzerkill.html
mickeykreg is offline
Old 08-24-2008, 09:54 AM   #3 (permalink)
mickeykreg's Avatar
__________________
85 4runner
Old 09-05-2008, 10:26 PM   #4 (permalink)
i am having the same issue in my 86 runner. i have yet to tear into it due to a hand injury but the first place i am going to look is the door pin. check yours to see if it has corossion on it or something from preventing it from making contact on the back when the door opens
drpdmazda is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Is the rear dome light supposed to come on when the rear hatch is open? 97 4runner newbie212 95.5-2004 Tacomas & 96-2002 4Runners 5 01-06-2008 05:55 PM
Dome Light not working for drivers door 2wd_tuff 95.5-2004 Tacomas & 96-2002 4Runners 0 12-17-2007 12:43 PM
Dome light only works with ignition? grayguy 86-95 Trucks & 4Runners 3 12-11-2007 05:24 AM
Driver door dome light switch, wiring issue patallen 84-85 Trucks & 4Runners 1 10-11-2007 09:43 AM
Dome light or door switch ground oldrew 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 8 10-01-2003 12:12 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
